Something I never mentioned were my side tables. I tried to solve the issue of where to put drinks and food, safely. One advantage I love with the dedicated home theater recliners many people buy are the arm-rest drink holders. No such luck in a sofa.
After a LOT of searching while designing my room I found these side tables (sorry for the old, crappy cell-phone photo, taken in-store):
They are just like (or actually are, I'm not sure) the well loved George Nelson Tray Tables. And at something like $400 each, darned expensive (and that was on sale!)
But....they were perfect. The feet slide under the sofa if desired so the table can end up right beside a viewer (not in front, visually distracting). The height is easily adjustable - a great feature I use constantly. They take up minimal visual space and to top it off the wood finish was a perfect match for the room. The store had only 2 left, no one else had them, and they were not importing any more. So I snapped up the last two.
I've been meaning to find some good car-like drink holders, have a couple holes cut out in each table, and insert the drink holders so drinks will be held firmly.
UNFORTUNATELY...
While on vacation these past two weeks I had some family house-sitting. I taught them to use the projection system which they loved. However, at one point (after inviting a bunch of guests over) one of the side tables was placed back behind the viewing sofa, but in the path of the projector lift. When my guests pressed the button to lower the projector lift back to it's sitting position it caught on the side table, crushing it downward, and snapped the table off it's metal stem. What a bummer!
A brief look on the web is telling me replacing this table is going to be damned expensive. I hope I can get someone to weld the table top back on or something.
Ah...it's always something isn't it?
UNFORTUNATELY...
