AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Rich H's Variable Image Size Home Theater - Build Thread - Completed!
Rich H's Variable Image Size Home Theater - Build Thread - Completed! - Page 8
post #211 of 212
Let me add to the above question Rich. I am thinking of adding velvet curtains down both sides. I am planning the build of a reno of my basement now so can work in what I want.
One black hole (pardon the pun) for me is how much space I need to plan for to accomodate these side curtains (they will run about 3.5 m). I'll probably go Fidelio although might go instead for the Black Plush Triple from sys. Either way I would guess curtains made of those materials are thick and bulky so thanks to give me an idea of the size of cupboards I need to build to hold them out of sight when not in use. It'd be nice if I had a sense of both the width required as well as the depth.
Congrats on your build by the way, fantastic stuff and loads of good ideas,
Dave M
post #212 of 212
Originally Posted by Elix View Post
Hi, Rich! I'm interested how your curtains are mounted to the ceiling. Some kind of rails system?
Are you talking about the curtains that I use to pull around my walls? Yes they are on curtain rails, hidden between the drop down ceiling portion and my side walls. You can see photos of the track
a page or two back in this thread.
My black velvet masks also ride along a curtain track, but it's motorized. Pictures of that track are also in this thread, page one or two I think.
