Originally Posted by
jang790
i have kind of read those but still .. cant make my mind .. in youtube there are videos where owners praise they lg hs201 .. so im kind of leaning to you guys.!! i play ps3 games and watch blue ray movies also which one will be better projector
I think then none of these should be your choice... the casio would be more fit since it has 16:10 aspect ratio, while LG has 4:3. LG has 2,000:1 contrast ratio while Casio has only 1,800:1. Both are not what you're looking for. If you're only going to use this for leisure (ie: games and DVD/blu ray, entertainment unit). Don't spend $1,000 on a semi-good projector. Go for Optoma HD20 or BenQ W1000 or Mitsubishi HC3800.
http://www.projectorcentral.com/Optoma-HD20.htmhttp://www.projectorcentral.com/BenQ-W1000.htmhttp://www.projectorcentral.com/Mitsubishi-HC3800.htm
All these choices would be about the same price as the Casio but be a lot better. The only upper hand the Casio has on these other projectors is that it uses LED technology which would save you in the long run for bulb replacements. But it's up to you. Because the picture quality on the Casio will definately not fall even WITHIN par with these Home Theater projectors.
However, if you might use this projector at the same time for business presentations and what not then the Casio might fit your needs. Otherwise I don't even know why you looked at this projector. That Casio isn't even for Home Theater. Check out the Optoma, BenQ, and Mitsubishi I recommended you. They are definately better!
