AVS › AVS Forum › Audio › Receivers, Amps, and Processors › OFFICIAL Sony STR-DN1010 3D-Ready HDMI 1.4 Receiver Thread
OFFICIAL Sony STR-DN1010 3D-Ready HDMI 1.4 Receiver Thread - Page 9
post #241 of 357
Originally Posted by - wardog - View Post
I assume you repeated this with the mic in the same position? Try repeated tests, moving the mic for each test and see if you can duplicate this.
Auto-cal and all it's whiz-bang technology aside, one should reasonably be able to hear an out of phase pairing of the FL and FR.
If your room and system(FL+FR) placement allow, with the SP PATTERN set to 2.0(only FL+FR), place yourself centered between and at equi-distance out front of the FL and FR and listen to a bassy 5.1 encoded source. The sound you hear should itself be sonically "centered' between the two speakers. Like your eyes can actually focus on where the sounds are emanating from between the two speakers. Not sounding as if it is coming from behind. Or that eery "inside your head' , WTF sense/feeling.
Also, the below is copied from the 1010's manual. Again, I believe it represents what the mic is "hearing' sonically due to room, furnishings, and or system placement. Whiz-bang.
Do the simple test above first. Given the mic vs human ear, I'd vote human ear.
pg 41 of the available online manual I have here states:
Code:
*When the speaker(s) is (are) out of the phase,
OUT is displayed on the TV screen. The
+ and - terminals of the speaker may be
connected the other way around.
However, depending on the speakers, OUT
appears on the TV screen even though the
speakers are connected properly. This is
because of the speakers' specifications. In
this case, you can continue to use the
receiver.
post #242 of 357
I don't know why it's so difficult - speaker wire generally has one side that has a stripe running down it - just make sure it's in the same (pos or neg) position on both the speaker & receiver, and you should be good to go...unless i'm missing something here...and I've been known to miss things...
post #243 of 357
I just could not tell you why its saying "out" but I switched out my bookshelf speakers and used my Paradigm monitor 9s as the test dummy and it read "in". I know its not the wiring in the reciever and its not the speakers due to the fact I switched right for left and so on. I ran the auto cal 3 times in different spots and all came out the same. All in all I'm just going to leave it wired the way it should be even if the 1010 reads out of phase. Thanks for all the input.
post #244 of 357
So I have the 1010 with an HDMI from my Verizon Fios box but I do not get any sound even though the program watching is 5.1 surround sound. I have put it on standby to get sound from my tv speakers instead. I then switch it to the PS3 and no problem there. Is there something I have to change to get sound from my Fios Box?
post #245 of 357
Hmmm, I'd check my settings/assignments for the inputs first.
Settings > Input (whichever one you have your HDMI from the Verizon box)
In the Manual, > Advanced Operations > Enjoying the sound/images from other inputs.
post #246 of 357
Purchased the DN1010 recently from a well known retailer in Washington state at a nice discount.
This to replace a Sony 820. Installed last Wednesday and can report all features work as advertised.
The AVR is connected via HDMI to an iScan Duo (Audio only) HDMI output and properly decodes the audio from all eight devices connected to the Duo including a NeoTV550, Dune H1, Tivo Premiere and 2 BD Players, Toshiba HDDVD player, Mits S-VHS VCR and Pioneer Laserdisc player.
I would have no reservations in recommending this AVR.
post #247 of 357
I bought a 1010 in December last year. Despite some annoying things (not being able to rename or disable inputs, hdmi control switching samsung tv input to tv instead of hdmi1, etc.). I found ways around them and was general happy with the receiver at the price. However, recently when planing blu ray discs the hdmi cuts out. Signal is lost and it takes many seconds to re-establish the signal. This is completely unacceptable for watching movies as it occurs quite frequently. I have reviewed all my settings and cannot find a cause. As near as I recall it didn't ever do this prior. If I can't find a solution soon, I'm going to need a new receiver.
This replaced a yamaha receiver that had worked 100% for years. Just didn't have 3d pass thru or multiple hdmi inputs.
My setup is a samsung 55" 7000 series 3d tv. On hdmi out with arc.
Blu ray is samsung 3d blu ray that came with the tv. On hdmi2
Directv satellite on hdmi1.
Xbox360 slim on hdmi3
Wii on component input.
It's in an open cabinet with plenty of air flow. It may have an occasional movie or game case laid on it, but I've never noticed it to be hot ever.
Suggestions?
post #248 of 357
I'd say try using different hdmi cables, it may be your blu-ray player so don't rule out the reciever. You can rename inputs through the menu on the reciever for some reason its not possible in the gui.
post #249 of 357
stickmonkey
The initial setup pamphlet recommends a Factory Clear before first use, a procedure I followed. Press power on the AVR for 10+ seconds.
This may be advised since final factory tests may leave miscellaneous settings in the flash memory which could return to haunt the owner.
While this may not account for your problem a factory clear may still resolve your difficulty albeit at the expense of losing your settings.
Beyond that HDMI can be tricky especially cables. I use Monoprice HDMI cables exclusively and never have problems with those.
Having read this entire thread IMO some of the reported problems seem to be due to user (cockpit) error. This is a complex device with a myriad of settings, it takes time and effort to understand.
I keep a copy of the user manual (pdf) on the computer for reference when changing settings on the 1010
post #250 of 357
post #251 of 357
Originally Posted by catmother View Post
Good review on the DN-1010 here:
http://www.hometheater.com/content/s...00-av-receiver
Um, ya better look closer. Even the linkage pasted states DN1000.
post #252 of 357
Haha! Good catch!
post #253 of 357
Not that much difference between the 1000 and the 1010.
Chief differences are HDMI 1.4, 3D pasthru, ARC and HDMI pasthru on standby.
But there is always Cnet:
http://reviews.cnet.com/av-receivers...ml#reviewPage1
post #254 of 357
No. In all reality there isn't that much difference. More me poking ya than anything else.
post #255 of 357
Understood and you are welcome.
The 1010 does what is needed, decode the DBTHD and DTS HD MA bitstream relayed from a Dune H1 media player and other sources via an iScan Duo VP hence no need for any video processing in the 1010.
The Duo Audio only HDMI goes to the 1010 which works. The 1010 does not play nice with the Duo for video. Connecting the Duo video+audio HDMI to the 1010 wipes out the video for some inexplicable reason. No matter, don't need it.
post #256 of 357
No matter their both pieces of ****.
post #257 of 357
Don't post unless you own one.
Do You ?
post #258 of 357
Do You ?
I did, but I returned it for obvious reasons.
post #259 of 357
I found a great deal on a 2 channel power amp, can I connect it to the receiver using the cd/sacd pre outs. If so will I still have control of the volume/ bass & treble settings through the receiver. Basically using the 1010 as a pre amp. I will be powering paradigm monitor 9s for stereo listening.
post #260 of 357
Have never used this method so this is just a guess.
You may get analog only, 2 ch stereo.
Advanced codecs, DB THD DTS MA can only pass via HDMI and may get lost via the SACD out.
Probably better to post to a thread dealing with SACD
post #261 of 357
Does anyone know how to get the sound to pass back to the TV from the Sony STR-DN1010 receiver using component cables? I hooked up my Wii to a Sony Bravia 3D TV and there is a picture, but I cannot figure out how to get the sound back on.
post #262 of 357
Component caries video only.
You will need to connect the 2 channel audio from the Wii to the corresponding audio input on the 1010 and let the 1010 convert to HDMI to feed the TV.
post #263 of 357
Hi sfoster9871, where is the Wii audio connect, tv or receiver?
post #264 of 357
Hello
I'm looking at upgrading my older Denon 1801 and just recently started looking at the Sony AVRs. I've been a Denon fan forever but based on what I'm looking for and budget even the entry 1911 is out-of-reach.
I'm interested in the Sony since we have a Sony 52Z5100 TV and Sony BDP-S360 BRP. Using the "sync" function would be useful. I just haven't kept up with performance and customer satisfaction on these. I know well of denons rep along with Yamaha and Onkyos which are two models I'm considering.
For the features, power, sync and overall features this can be had for around $300 average. My "budget" for now is $300-$350 max. I like the 'pass thru" feature but sad to see no usb port. Don't have a iPod or iPhone. Sound quality and getting True-HD and DTS-HD Master is my main concern since the 1801 Denon has none and still uses "S-video_ connections". I wanted to confirm that pass thru upscalling willl work component to HDMI since my 360 uses component cables. Streaming connections to one HDMI would be a big plus.
So for basic and nott everyday use (this is in the REC Room) how does this Sony stack up overall or should I go back and consider the Onkyo HT-RC360 and Yamaha RX-V567?
post #265 of 357
A good AVR for the price.
Have not tested the component to HDMI since every source in my HT is HDMI.
The Cnet review is a good start:
http://reviews.cnet.com/av-receivers...tml#cnetReview
The reviewer does state that the component to HDMI conversdion was not that great.
Your choice but the 1010 does everything I need at a budget price. Paid 250 on a special from a reputable etailer.
post #266 of 357
Well I'm about to cross the Onkyo RC360 off due to reading reviews all over about a few issues with the firmware upgrade, some quirks and once again heat, which Onkyos in the past seem to have as well. Some have also mentioned despite the power rating you need to push the volume control almost half way.
So how is the power/sound and about as important the heat?
post #267 of 357
Power and sound are fine IMO and the 1010 runs very cool, top only moderately warm after 1 hour use.
You are smart to read the threads an any AVR you are contemplating. The Onkyo problems are well known and of long standing.
post #268 of 357
I see the newer line of AVRs from Sony...820 and 1020 are out. Any word on them compared to the 810 and 1010 models? I do see a usb port for one thing. Some good reviews over at Amazon and even Crutchfield so far on the Sonys but nothing to much on the new line.
And yes i'm considering another model...Yamaha 667 and got a few comments about the "heat & hot" on Onkyo models. I'd love to see a comparion shot with severl model without their tops on so to see the heat sinks and layout. I still like the thought of "sync" with my Sony 52Z5100 and BR player.
post #269 of 357
...I've had my DN1010 for a month and a half or so, and while the setup was a pain in the a$$ at times, it performs flawlessly with no issues as reported in previous posts.
As an added point, I definitely have not experienced the problems with the subwoofer (decreased output/power). Mine sounds just as good as it did with my previous Sony AVR. It produces plenty of bass...and there is no problem making adjustments, if needed. Most of the people noting issues with their sub are saying their sub no longer "shakes their entire room/house." My question would be, "why do you actually want/need that to happen?" If it has the ability to do so, great...if not, that's fine too...but how many times do you REALLY think it's necessary? If you have your sub cranked that high, it completely defeats the purpose of having the home theater setup in the first place. This line of thinking can be compared to people who insist on dumping $5k worth of subs/amps into their 1984 Toyota Corolla...complete with oversized spoiler and spinners.
post #270 of 357
Looking for a little help/advice here.
I picked up the STR-DN1010 a few days ago as the final update component to my HT. After spending most of the day getting it hooked up and working properly(?), I am not sure I am reaping that much,if any benefit (other then the hdmi/3D passthrough) over my old Sony STR-DB930. Both using paradigm speakers.
I was really looking forward to the benefit of hearing trueHD audio, but in the brief usage using BluRay source audio, I hear little if any improvement. Before spending a lot more time trying to tweak this receiver for the best audio quality, just wanted to check if I may have taken enough of a step down in receiver/sound quality to eliminate the benefit of processing TrueHD audio. Or are my ears/hearing just getting too old to tell a difference?
Thanks for any help/advice/suggestions.
