Originally Posted by
MD_Gamer
So, I bought this on sale on Cyber-Monday for a steep discount. I can return it until January, and I probably will unless I can figure out some issues.
I recently bought this receiver as well and It has worked out pretty well so far since I have a fairly small living room. I will try to address some of your issues below.
MD_Gamer
First, I can't configure the input organization in a sensical way. I have 4 HDMI devices, one of which (my Macbook Pro) can't do audio over HDMI but does have optical out. I also have an Airport Express with digital audio out. With 13 input labels on the remote, you'd think it'd be simple to find a good way to handle each. Except: BD, DVD, and SAT/CATV can handle HDMI video but NOT HDMI audio, while the HDMI-labeled inputs cannot be paired with optical audio under their own label. That is, I can't press the "HDMI 4" button and get HDMI 4's video with an optical input's audio. I also can't pless the SAT/CATV button and get HDMI 1's video and audio together.
BEFORE YOU BUY THIS RECEIVER check the input assign chart on page 87 of the manual (available on Sony's site as PDF). All of this would be less of a problem if there were a way to cycle through inputs, with some disabled, and the
real ability to name inputs (see below).
Yeah, it is a bit strange that you can't set the "non-HDMI" inputs to use HDMI audio. However, I don't think this is really that big of a deal since you can simply use the HDMI inputs and rename them. Also, as you said you can assign the other inputs to HDMI video and optical audio so that solves your problem with the Macbook Pro.
MD_Gamer
Also, since I've told it that SA-CD/CD has no video input ("NONE" in the input assign menu") when I switch to SA-CD/CD it gives me the video of the last video source. If there are no active HDMI sources, it sends no signal to the TV, which is a pain since it isn't smart enough to let me turn off just the TV when using that input. My temporary fix is to assign it to an analog vifdeo source so that it just sends a black screen to the TV. Still a waste of power, but at least I don't get mismatched video or a blue "No signal" screen. Same for the FM/AM tuner, although it just displays the barebones tuning interface on the TV. Forever.
There is a way around this which may be a pain depending on how you look at it: Simply turn on the receiver first and don't turn on the TV. I have a Sony Bravia LCD with Bravia Sync enabled. If I turn on the TV it automatically turns on the receiver. If I then turn off the TV it automatically turns off the receiver as you said. The FM/AM tuner only displays the barebones tuning interface if you select it through the onscreen menu in GUI Mode. If you press the GUI MODE button again it will go away and you can listen to the radio while watching video from another source. If you select the FM/AM tuner using the TUNER button and bypass GUI mode you won't run into this problem.
MD_Gamer
While I'm (still) on the topic of inputs, let me point out that naming an input is pretty damned useless. Although you can type in a short ASCII name, that name will only appear in the on-screen GUI. It doesn't appear on the TV or receiver when switching between sources. Why bother naming an input if you'll never, ever see that name except for a deep submenu.
This is absolutely incorrect. I have renamed my inputs and the names show up fine on the front of the receiver. One problem you may be running into is that if you select your input from the onscreen display in GUI mode the receiver will continue to display "GUI" on the front after the input has been selected. While "GUI" is displayed on the receiver you can't use the DISPLAY button to cycle through the various display options. You have to press the GUI MODE button again to get rid of this. Once this is turned off the DISPLAY button will work and you can cycle through the various options. Another way around this is to simply use the buttons on the remote to switch inputs and don't go through the onscreen menu.
MD_Gamer
My second problem, which is actually my biggest dealbreaker, is that this receiver adds 40-50 ms of delay to the video. The receiver includes an audio sync feature so that you can re-sync (to the nearest 10ms), but for video gaming, this is horrible. I'd consider running the HDMI and Audio separately if not for the limited number of optical inputs and the need to then switch the video and audio separately.
I can't really comment on the delay issues as I haven't run into any lip sync issues. I'm a bit puzzled why you said you need to switch the audio and video separately since as noted above you can set some of the inputs to use HDMI video and optical audio.
MD_Gamer
The third problem, which is more of annoyance than a problem, is that this thing takes a very long time to start up (and switch inputs). My roommate couldn't figure it out while I was gone because the TV displayed "No input signal" for so long that he figured I hadn't hooked it up.
Yeah, it can take a while but it doesn't really bother me since I'm not constantly switching inputs back and forth.
MD_Gamer
The fourth problem, also more of an annoyance than a problem, is that I can't playback the audio from multiple sources. This is a feature of analog receivers that you don't know you miss until it's gone. Gone is the ability to play music or listen to a sports game in the background while I game (unless I make my gaming machine handle the music as well, which is less-than-optimal). I guess this is due to the expense of including extra chips to decode multiple audio signals and mix them?
Interesting. I've never tried to mix audio channels together so to me this is a non-issue. Obviously you could still listen to a CD or the radio while a game is on the screen.
In case anybody else is interested, this receiver will overlay the on-screen menu for analog video sources (I've only tried with component). This means that it will also overlay the receiver volume indicator on the screen while you are watching TV. However, it will not overlay the on-screen menu for HDMI sources. There is a slight workaround through for displaying the volume onscreen with an HDMI source using Bravia Sync. In the receiver under "Settings" and "HDMI" set Audio Out to "AMP" to turn off the TV speakers. You can then change the remote to TV mode using the TV button next to the SHIFT button (not the TV source button). Once the remote is in TV mode you can change the volume and it will use the TV volume indicator on the screen. However, this will actually change the volume on the receiver since you have the audio set to "AMP". The only downside is the numbers for the volume level on the TV and the receiver don't match.
