Wdtv live plus hd - Page 28
post #811 of 826
Originally Posted by Buyshop View Post
Ok. I never did remux. If you tell me how to do that ok. Software name etc
Mount the ISO and browse to the BDMV > Stream folder which has all the m2ts. Double-klick on any m2ts to see what clip it is (that's assuming each clip is one m2ts). Open that m2ts in TsMuxer, select M2TS muxing as output, switch to the Split & Cut tab and select "Split by duration every 60 sec". Upload the first m2ts to sendspace.com or something.
post #812 of 826
New firmware update available for the Live SMP. Officially supports dts-HD passthrough. Works great! I've verified with multiple titles (Pacific Rim, Oblivion, Elysium, Iron Man 3). So far I've encountered no real negatives so this feels like a solid update.
post #813 of 826
I am using a powered usb hub to connect 4 external harddrives to my WD Live TV. The drives show up as disk-0, sdb1, sdc1, sdd1. How can I rename these to another name? I have tried every way I can think of but nothing will allow me to change then name. Can anyone help me out?
post #814 of 826
I do not believe it is possible to name them. The OS of the Live + simply identifies them as attached HDD's and gives them default names as it finds them.
post #815 of 826
OK i have a question for ya. At one time before I used the hub and only when i have one hard drive connected the empter folders that i have on my hard drive that dont have any media in them didnt show up. The folders only showed up when there was media in those folders. For example I watch Mike and Molly and I created a folder for that show. When there are episodes in that folder the folder showed up on the wd and when there wasnt any episodes in the folder the folder didnt show up. But now since i have the hub on it always shows the folder even thought there are no episodes in the folder. How can I fix it, I want it to not show folders when their isnt any episodes in the folder.
post #816 of 826
Will the new firmware update for the Live work for the plus to open up dtsma passthrough??
post #817 of 826
No, it is only for the Live-SMP. There will likely be no further updates for the original Live or the Live +.
post #818 of 826
Any big reason to update form a Live + box?
thx
bob
post #819 of 826
thx
bob
I have them both. The Live-SMP has a nicer UI, fewer bugs around network connectivity, bitstreams DTS-HD, is still supported with firmware updates.
post #820 of 826
shall I choose 1080/24 or 1080/60 in HDMI for WD TV Live Streaming?
Options
I just bought JVC projector x35 and now want to pair it with my WD TV live streaming for ISO/BDMV/MKV movie file play. someone says all blueray movie file is 24P, so shall I choose 1080/24 or 1080/60 in HDMI for WD TV Live Streaming?
Rds,
post #821 of 826
Options
Neither.
Choose Auto and let the Live negotiate the HDMI link for the max compatible resolution with your device.
post #822 of 826
Originally Posted by Kelson View Post
Neither.
But there are several comments that the auto is not working well on WD TV...and it will not correctly choose 24P
post #823 of 826
It certainly does for me
post #824 of 826
Anyone else having problems with the plus connecting to netflix
Sent from my SAMSUNG-SGH-I437 using Tapatalk
post #825 of 826
Did the livehub get similar HD pass through? I've only been using DTS on it and I cant seem to find anything definite.
post #826 of 826
Nope the Hub is end of life/discontinued frown.gif
WD stated on the WD Community site no more updates.
