Greetings,
I've been reading so many posts about spyders and other tools, yet I feel I know nothing
After reading about the bad experiences peeps have had with the Spyder3TV model I decided I am not going to waste my money on that.
However, I can't really find anything about the Spyder3Pro model. I've read about the freeware software too but forgive me its all overwhelming since I've never worked or done any calibration.
I'm buying a new TV, 50" plasma from LG, a 50PK250. I will be reading up on how to handle the first few hundred hours, but after that I'd like to properly calibrate it. Point is, I don't want to spend hundreds of dollars doing so.
The Spyder3Pro is only a couple of tens more expensive than the SpyderTV. If that model works with the freeware software provided here, what will I be able to do? Following a dummy guide, will I be able to do a proper calibration for home theater use?
A question you may not be able to answer, but will it be worth it? I've read a simple hack will enable a THX option on this model which already gives a very good image. What will a calibration improve on top of that?
Cheers,
Ingemar.
Cheers,
Ingemar.
