AVS › AVS Forum › Audio › Receivers, Amps, and Processors › help with bryston amp
post #1 of 8
Hello guys, well I got a 3B amp to replace my NAD 2200 and , I can't get no sound out of it!, I took the Nad out and plugged everything just like it was, but nothing, the green lights come on but no sound at all ! , well I actually get a weird sound from the speakers when I turn the amp off. Any advice??? Thanks. I am using a Marantz 7002 as pre.
post #2 of 8
Find your local Bryston guy or any high end repair shop. Sorry. Great freakin amp! Worth the repair.
post #3 of 8
Well, I just got it from E..y ,so I will see if I can make it work, I wonder if the amp can be hooked up to any AC outlet???, the fuzes look good, any ideas ???
post #4 of 8
A little bump!
post #5 of 8
Contact James Tanner at Bryston. He's on audiocircle daily and will help you out.
http://www.audiocircle.com
post #6 of 8
Could the stereo/mono switch possibly be engaged to mono?If it is and you have your cables in the wrong input, you might get some type of feedback.
post #7 of 8
llep
Your welcome! Just saw you on AC.
Good Luck with the amp
Mark
post #8 of 8
I love this forum members!, thank you guys, will see what the problem is.
