AVS › AVS Forum › 3D Central › 3D Content › Comcast 3D topic
Comcast 3D topic - Page 25
post #721 of 734
3D from Comcast (either their 3D channels or on-demand content) will always look worse then a 3D BD disc. Currently the 3D resolution from Comcast is 1/2: meaning it's no where near HD quality since the normal quality is cut in 'half' to send one frame per eye.
post #722 of 734
1.3 can support up to 1080i 3D but not 1080p and since Comcast doesn't broadcast anything higher than 1080i his receiver will work. How do I know? My Denon 3808 is 1.3 and I get to watch ESPN3D and Comcast 3D nooo problem. Cheers.
Hi all, is the above still true? It is from page 16 of this thread and a few years old now. I want to know if i can use my HDMI 1.3a Yamaha RX-V1800 for comcast HD or if i am going to have to send HDMI to my projector and optical out to my receiver.
post #723 of 734
Your receiver will not pass Frame-Packed 3D content (such as from a Blu-Ray player), but Comcast currently only broadcasts in the SBS (Side By Side) or Top/Bottom 3D formats. You shouldn't have any problems if you connect your Comcast cable box directly to the Yamaha...even the 1080p content from Comcast will pass through as the HDMI v1.3 spec fully supports that resolution.
post #724 of 734
Sweet! Does this mean that any current Comcast box that outputs HDMI will send 3D as well?
post #725 of 734
Yes. They only have the 3Net channel left in my area, but it is pretty good with some shows which feature a lot of pop-out. Unfortunately, it is all just 1080i...for 3D 1080p on Comcast you must access their collection of OnDemand 3D movies.
post #726 of 734
This is great news! I spoke with a rep yesterday and was told that my current dvr box, which sends out HDMI, would not support 3D. She said I would have to show up at my local store to swap mine out, and I could not call in advance to check if they even have any available! eek.gif
post #727 of 734
Which model DVR do you have? I can find out for you if this is true or not.
post #728 of 734
I will check when I get home tonight
post #729 of 734
Okay. I'll check with our local Comcast headend manager when I hear back from you.
post #730 of 734
It is a DCH3416
post #731 of 734
It is a DCH3416
That unit may or may not work, depending on whether or not Comcast is still using MPEG 2 in your location...if I recall correctly, they switched to MPEG 4 for 3D broadcasts back in 2010/2011. Which city are you in?
Edited by Rudy1 - 3/19/14 at 4:20pm
post #732 of 734
I am in Boston
post #733 of 734
I am in Boston
You will probably need to get a new DVR that is MPEG-4 compatible. The DCX series DVRs should work.
post #734 of 734
Ok, I will swap mine out, thanks for the info!
  Back to Forum: 3D Content
