I'm also in the market for a multi-HDMI output receiver. My application is for 2 TVs in my basement Bar / Lounge. 1 behind the Bar, 1 main TV.
The idea was to have selectability in which TV see's what, while having the audio go through the receiver as well. Unfortunately, spllitters, or switches don't enable this.
Splitter on receiver output: Can't have 2 TV's display different things, only the same feed.
Splitter on receiver input: doable, but you need to have a splitter on each source, and an independent cable run for each source to each TV
4x2 switch: Works if you want to display any feed on either TV, but still doesn't address the concern that if you want HDMI audio, you either need to have an HDMI 1.4a TV and receiver to get audio return, or use optical (or equivalent)
4x4 matrix switch: having 4 in 4 out, this allows you to select the video source which each TV sees, while also routing HDMI audio to the receiver. Best of both worlds. If the receiver has multi-powered zones, than you can ultimately have 2 independent viewing and audio environments. Movie on 1 TV, sports on the other.
Monoprice has a decent 4x4 matrix for ~$160. Seems like this along w/a harmony remote to control the switching & macros, and a decent HDMI amp is the way i'm going to go. I don't want to wait, be limited, or go broke deciding between a select number of high end receivers.
