AVS › AVS Forum › Audio › Receivers, Amps, and Processors › List of entry level Receivers with mutiple HDMI out (2 HDMI out)
List of entry level Receivers with mutiple HDMI out (2 HDMI out) - Page 11
post #301 of 323
Here is a link to the owners thread for the 3313ci. jd and others have done a pretty thorough preview and anlysis of the features there http://www.avsforum.com/avs-vb/showt...ghlight=matrix
Gear mentioned in this thread:
post #302 of 323
Ok. I recently lost a Denon 2310CI because I was screwing around trying to get a goddamn HDMI splitter form monoprice to actually work. Can anyone give me a reason NOT to buy one of the cheap Onkyos? Or would Yamaha/Pioneer be considered good? I've seen widely varying reviews on this stuff lately. It seems like not even Denon has good quality control, considering some mentions I've seen of flaky HDMI on the 3312CI. I thought about getting a refurb 3312CI, but now I'm not sure that's even worth it.
post #303 of 323
It's a way broader question just asking about cheap receivers. We're more interested in the "2 HDMI OUT" aspect in this thread. Here is a link to the results of a "good cheap receiver" thread search on AVSforum
http://www.avsforum.com/search.php?search=Good+cheap+receiver
Edited by Thud2 - 6/25/12 at 11:12pm
post #304 of 323
and I need 2 HDMI outputs, which is why I asked in here. I'm only asking for opinions based on the list at the beginning of the topic.
post #305 of 323
I don't trust ONKYO after my experience with the HDMI board failing on my 606, alot of others had the same experience. There are links to reviews and to the owners threads in the table in the first post if that helps. I'm happy with Yamaha RX V867 that I settled on.
post #306 of 323
post #307 of 323
Onkyo Released the 1010 with 2 hdmi out for $1,799, looks like 2 HDMI out is getting to be standard equipment! biggrin.gif
post #308 of 323
The Yamaha Aventage Series is out and all have 2 HDMI out. http://usa.yamaha.com/news_events/audio_visual/yamaha_aventage_series_network/
post #309 of 323
Originally Posted by felickz View Post
The AVR we are all waiting for... IS ANYONE LISTENING?!?! .. no
Looks like the manufacturers finally got the message!
post #310 of 323
Most of the cheaper ones don't have reviews or owner threads. Nothing seems to have good quality control anymore. Everything gets made with the same cheap asian parts that fail. Also, why the hell is that Pioneer VSX-9140THX on the list 3 times with no info? I can't even find that model on google/amazon.
post #311 of 323
You can find most of the ones with a list price below $1,000 or so for much less online. My RX V867 lists for $899 and I paid a fraction of that for it and it' seems like a pretty solid piece of kit.
post #312 of 323
This is proving to be a very frustrating search for me. I need to keep the budget down on my project (screen + projector with 3D). My Onkyo 707 doesn't do 3D so I need to upgrade. I was going to go with an Onkyo 709 but it seems QC may be an issue. I have found the RX V867 at a decent price but my Dad's experience with Yamaha has been less than stellar. I have also found a VSX-33 at a reasonable price, but I'm worried about issues between that unit and my Samsung TV.
I'm honestly getting tempted to give up on the 2 HDMI outs and get a good unit + an HDMI switch... but that also brings possible issues.
*sigh*
post #313 of 323
You're worried about Onkyo, you're worried about Yamaha, you're worried about Pioneer... Bro, you worry too much.wink.gif
post #314 of 323
post #315 of 323
I can understand, it's a big investment.
post #316 of 323
Yes it is, and it's an important one too.
Right now I'm think I'm down to the VSX-33 which I can get used for $430 and a used (or refurbished) TX-NR709 which will cost me $500. I've had Pioneer in the past (VSX-1014TX) and right now I'm using the Onkyo 707 which has been great. One thing I really like about my 707 is Audyssey. It did such a great job with my room compared to the MCACC on the Pioneer.
post #317 of 323
My recent subjective experience with Onkyo and Yamaha is this. I had an Onkyo 606 which had great power. I have an old Velodyne Front Row surround setup and they are not small by Home theater standards (surrounds weigh almost 8 lbs) . The Onkyo drove them well but the dreaded Onkyo HDMI board failure got me right after the end of warranty. As an interim solution while I saved for a 2 HDMI out receiver I bought an Onkyo 303. A little underpowered but still up to the task. Then I got the Yamaha RX-V867. Sound Stage is good, seems to have a little less grunt than the Onkyos though. HDMI switching and routing is flawless though. Am not able to crank up the system lately anyway so accuracy trumps efficiency in my current situation anyway. Happy with the RX-V867.
post #318 of 323
post #319 of 323
Only 25 watts? is this a Blu-Ray Preamp?
post #320 of 323
Marantz has a new model, The SR7007, which has 3 HDMI OUT!!! I think Thats a first!
post #321 of 323
Several mfr's offer a second Zone HDMI out to include Denon (3313CI, 4520CI), Pioneer (SC-67/68), and Onkyo (3010/5010) at a minimum.
post #322 of 323
Whats up smoothie. Do others have 3 HDMI out? Haven't been staying on top of things. : [
Edited by Thud2 - 10/14/12 at 7:41pm
post #323 of 323
My 3313 has 3 outputs, 2 on Zone 1, and 1 for Zone 2. It's pretty slick, works quite well.
