AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 1919 w/ ok speakers vs Pioneer 820 with really nice speakers
post #1 of 32
I am a complete audio newbie. I took a lot of time, weighed all of the receivers vs my needs and decided that the Denon 1910 was the system for me.
However, I when I started looking for speakers in my price range ($200), I found out that I really should be investing more in speakers than the receiver.... I bet this is a common rookie mistake.
I want a mic for setup (i don't know how to setup a system).
I am a gamer / movie watcher with a 15' x 15' room. I don't care about sound volume as much as quality of sound. I love to hear the small distinctions more than a big booming bass.
So, here are a few options I am considering. I hope to start some conversation.
1. Denon 1910 with Jamo S 413 HCS 5. - total cost 600+ship
2. Pioneer 820 with Jamo S 413 HCS 5. - Total cost 450+ship
3. Pioneer 820 with Energy Classic (or micro) - 650+ship
- I am little humbled by the options -
John
post #2 of 32
Why not consider the Denon AR-1610 with the Energy Takes
You are generally better off spending more money on your speakers than reciever
post #3 of 32
Rule of thumb is to spend about twice as much on the speakers as you do the AVR. Both sets of speakers are a good matchup with the Denon 1910 although as noted, unless you need a 7.1 setup, the 1610 is the better buy. You best bet is to audition each set of speakers if possible and choose the set that appeals to you the most.
post #4 of 32
I was afraid you would agree with the 2:1 rule. What I don't understand is, these speakers are not twice as expensive as the 1610 or the 1910, would they truly be a good match? Or would I have to spend 1000+ on the speakers to make stepping up to the denon worth it. That is why I was suggesting going with the 820.
I will try to find a shop nearby that has Jamo's. For $200, they could be a great option.
post #5 of 32
That's simply a "rule of thumb". There are thousands of folks that are very satisfied with their < $500 speakers or HTIB systems.
post #6 of 32
There is no rule of thumb. At a limited budget, buy an AVR with the bare minimum of features that you need and spend as much as you can on speakers. At a higher budget, buy speakers that are good enough for you and the receiver that has as many features as you want.
I'm not sure "really good speakers" have been mentioned in here at all, personally.
post #7 of 32
My dilemma is that I don't know if I will turn into an audiofile. I tend to be very picky about all of my other gear so I expect that I will want to upgrade later.
Having access to Denon 1910 units for only 375 shipped seems like a unit that I could upgrade in the future.
I am tempted to get that receiver with the energy take classics. I do not need a lot of power. I just want a very clear signal and I want the signal to be clearly separated to the channels. I like the low hz and low ohms of the Jamo's though.
Conversely,
So, if I were to get a $200 unit, and I could spend $500 on speakers, what speakers should I be looking at? Any suggestions. (this sounds like a slippery cost slope) What is a good mid range speaker in that price range? Or this might be more helpful. If you had only $500-$700 for the total system, what would you buy?
Thanks for the help so far guys,
John
post #8 of 32
Check out this thread on Jamo speakers. Then you can decide for yourself if they are worth an audition.
http://www.avsforum.com/avs-vb/showthread.php?t=872526
post #9 of 32
Are you up for buying used equipment?
post #10 of 32
Used / Refurbished are okay. Just as long as it seem reputable.
I have looked through only a few pages of the Jamo thread before. I was turned off because they were talking about the top of the line Jamo's, not the entry level ones that i am interested in.
post #11 of 32
What are the physical size limits on speakers?
Another thing: I'd consider not doing 5.1. Maybe 4.1 or even 2.1.
post #12 of 32
I currently don't have a big size limit. I have ones that are 40" tall and 10" width and depth now. They are junk though. I guess i wouldn't want something too much bigger.
Keep in mind that I don't need a huge amount of sound, just clear. (i don't know why I would need really tall speakers) I would like to keep the rear speakers smallish. I planned on wall mounting them.
I was thinking that Jamo 406 setup might be good for a little bit. Then I can determine if I want to get a sub later. If I decide I don't like the front speakers, I can always upgrade later, keeping the rear ones the same. Would that be good paired with a Denon 1610?
post #13 of 32
Well, this is very subjective, but personally, I'd go for a subwoofer long before rear speakers. I don't recommend a center at all at a low budget unless your seating position sucks. IMO, fronts > sub > rears > center
I'm looking through Audiogon to see if anything jumps out at me...
post #14 of 32
Okay, I stumbled on this system. It is a touch over $500 so it is getting out of my price range.
Klipsch HDT1000 HD Home Theater Speaker System
-looks like it has good watts and okay hz. Not as good Hz as the Jamo though.
I also was thinking about this from Definitive Technology -
5.1 home theater speaker package
ProCinema 60.6 (Black) - $400
Or this setup as suggested in another forum - I like this setup because I can upgrade the center channel later. If i want to I could bump up to a better L and R from the same company.
Infinity P142 X 5 =$225 http://www.theaudiovideosource.com/InfinityPrimus.html
BIC V1020 Sub = $145: http://www.amazon.com/BIC-V1020-Down...f=pd_rhf_p_t_2
How would these setups compare to the energy classic for clarity? I have found the energy classics for $300.
post #15 of 32
Another option is 2 Polk Monitor 50 floor standing in front -
http://www.amazon.com/Polk-Audio-Mon.../dp/B0002Z240M
and 2 infinity 142 in back
and that BIC sub for 150. That puts me at 450+ship.
Better than the Klipsch package deal?
post #16 of 32
All I can say about speakers, especially Klipsch and Infinity, is that you need to listen to them before buying. They practically make my ears bleed (at least their cheaper products do) and I know I am not alone in this. Way too bright. Listen first! Caveat emptor!
I don't like the idea of upgrading speakers later, personally. I'm more into the "do it right the first time" idea. I'd rather add on speakers than replace speakers.
post #17 of 32
Then you need to read the reviews from people who are using these Jamo's. For $200 it won't cost much to audition in your home and if you decide thet are not for you send them back.
http://www.vanns.com/shop/servlet/it...06-hcs-1-black
post #18 of 32
From what I saw, the Jamo's had great reviews. I am quite tempted. But it is still great reviews for a low / mid level speaker (i am assuming). I think that the systems that Donoman wants me to purchase are a little pricier.
How do the Jamo's compare to the Energy classics? I still haven't found a setup (even 4.1, I need to set this up as surround to start for gaming) that fits my needs and would be in that good mid level range.
post #19 of 32
That's true. I do agree with what he says also about speakers. Get the very best you can afford. However a lot of people cannot afford the very good speakers at this time. Another option of course is get what you can afford at this time and sounds good to you. Because you are going to upgrade like it or not. You are entering an expensive hobby and you will find out you will never be satisfied 100%. There's always something out there better. But until you can afford this upgrade get what you can afford at this time and be happy until the upgrade bug bites again. Good luck and I hope you are able to find something you can be happy with for a long time.
post #20 of 32
Well, I haven't given any specifics. I just don't like overly small speakers. As they often say with cars, "There's no replacement for displacement." That statement is even MORE true with speakers.
I have more mentioned what I would put my money into in your case, and that would be two speakers and possibly a subwoofer. I'd rather have two good front speakers and two crappy rear speakers than four mediocre speakers, also. Even if it means using Dayton B652s for rear speakers. But you're the one buying here, not me.
There are some fairly cheap Paradigm Titans on Ebay...
post #21 of 32
The Jamos at Vanns are not small speakers. The two fronts are towers and the center is also a good size. The rears on the other hand are small but do what they are supposed too. For the small investment for the OP at this time I feel they are at least worth an audition. Call Vann's, ask about return policy and go from there. Only takes a few minutes and he may end up with some good speakers to carry him over until he can afford great speakers.
post #22 of 32
I had the same problem with new polks. With music they were the harshest and brightest speakers I've ever heard.
post #23 of 32
Well, I am a sucker for quality (which is why I am scared of this new hobby) so I picked up a pair of Paradigm Titans. I will use them with my current knock off brand speakers as a 4.0 system until I get the cash to upgrade.
I do appreciate the support guys. I was very tempted to get the Jamo's. They looked like a great deal. Funny that I would be dissuaded by the low price.
~John
post #24 of 32
Okay, here is an update to my situation. I had some bad luck with used speakers so I am looking again.
- I bought a denon 1910 receiver for $360 shipped.
- I bought a pair of paradigm V4 titans. One showed up broken. It probably broke in shipping. I returned them.
- I bought paradigm cc370 center with ADP-170 v.2 rears. The center arrived with a broken tweeter. I am in the process of returning them.
Now, I am looking again. I went to ultimate electronics and listened to some speakers.
There are 2 speakers that I can afford that I liked the sound -
Mirage OS3-FS. My favorite from the showroom. They sounded great. Found them for $300 a piece.
Def Tech BP6 - good price point speaker. Found them for $225 a piece.
Klipsch Icon Series WF-35 - sounded awesome but i can't afford them.
Since these both are at the top of my range, I will just use my old white van MTS speakers as rears until I can afford more. I will run a 4.0.
I can keep looking for other fronts at $300 a piece.
My concern is that the mirages seem like a great deal but I am hesitant to purchase because of reviews that they sound very different at home. The ult electronics guy said that it is one of his most returned speakers. I have carpeting and walls on 3 sides around my stereo. The left side is open to another room. I wonder if I would have good luck with it.
1 more option is a guy is selling paradigm monitor 7 speakers that are 8 years old but still in good shape for $250 total. These ones I can listen to make sure they work but it will be in a garage. (poor acoustics)
I still have the option of the Jamo 5.0 setup for $250.
With the new price point of 2 speakers for $300 a piece, what do you guys think I should look into next?
John
post #25 of 32
Some other options are
Polk Monitor 70 - $170 a piece or
infinity primus 362 - $200 a piece
Thanks again guys.
John
post #26 of 32
The Jamo's or the Paradigms until they get it right. My first choice would be the Paradigms. Where are you getting these that are being destroyed in shipping? Hopefully its not your dealer. If it is you may need to find a different one.
post #27 of 32
They were used e-bay purchases. The first one was not packaged very well and it must have taken a serious hit. The second one seemed to have a wiring issue or something inside. I didn't want to tear into it instead of returning it.
post #28 of 32
Do you have a dealer of the Paradigms near you? If so go there and give these Titans a listen. Also make sure and listen to the Mini-Monitors. Excellent speakers for the money. If no dealer nearby, I'd go for the Jamo's from Vann's.
post #29 of 32
I am surprised that you didn't like the Mirage OS3 option or the Def Tech speakers. Those seem like good companies.
I really like the idea of floor standing speakers. I don't have a bookshelf system to set them on. I suppose I could hang them from the wall but it isn't ideal.
John
post #30 of 32
I'm the one that suggested he get the Paradigms from Ebay. I was not the seller (and I actually almost tried to get them myself but I really don't need more speakers). Sucks that he didn't make out very well. I would give that other guy's 20s a listen/try. I'd rather hear them outside than in a garage, or with the garage door open and them pointed outside (with not too much crap on the floor)
