7.1 is what creates a better surround effect, especially in larger rooms where you can adequately apply the two back surround speakers. I have tried only 5.1 in a room before 7.1 was done and there seemed to be a "hole" in the surround effects before it was done, as if something was missing and the surround effects were too localized with 5.1.
Recently, I did a setup using the 9.1 configuration using the Denon 4810CI - it is good, but its not as effective as the 7.1 in creating a fuller surround field, it seemed as though nothing was added (much) to the audio effects with DPLIIz processing as DPLIIx does, IMO.
