Originally Posted by Hoary
CD
UPnP worked for me when I enabled it in Windows 7 Home Premium. I didn't have any problem browsing pictures or playing that test file Micorosoft put in the video folder (Nature in HD or something). However, I suspect that even through PlayOn, Netflix is flash so it needs to be trans-coded to format VMP75 understands (same for the YouTube through UPnP). VMP75 is not suppose to play flash. From what I understand, YouTube and Netflix, when play natively, activate special programs which could not be activated when you using UPnP.
CD
OK, well I guess that explains it...but I still think this box had a shabby showing.
CD
- btw if your in the mood for trouble shooting, there's a new version of PO out now - v306.1075 (can't wait to install it and then start emailing PO support)
- and since August 5th, I'm still waiting for one of those 3 promises to call me back in 1 to 2 days
Like others it would seem that not only is the Samba client on the VMP75 bugged, but DHCP might have some issues as well. I'm using an Alfa WiFi dongle BTW (recommended on Viewsonic's site)
