I just joined after lurking the last year when I found this site. My problem is I have two Panasonic DMR-EH55S recorders that I bought new in the spring of 2008 to replace two other Pany's that were stolen in a residential burglary.
They have been performing flawlessly until last Saturday when I attempted to format a DVD+R DL disc in one of the machines. After the lengthy attempted format, which I thought might be a defective disc, neither machine will read any disc, including any commercial movies I have purchased.
I am stumped as to why they both failed at exactly the same time as I only tried to format the disc in one machine.
One machine failing I could easily understand. I have searched this forum as well as several Google searches for the cause of the issue to no avail. Panasonic tech support was of no help either.
I have disconnected the power for 48 hours and upon plugging back in the time reset correctly so maybe I didn't leave them unplugged long enough. I then tried resetting both machines to the factory defaults by pressing the channel up/down buttons at the same time. I have cleaned the hub and laser with alcohol and several Q-Tips. Nothing seems to work. Does anyone have any other suggestions I could try?
I might add that they are connected to two Comcast HD boxes with the included cable blaster for a digital HD source as well as HDMI cables to my Panasonic Plasma.
I hate to think about sending them in for repairs and also I am afraid if I do they will format the hard drives and I have several programs I need to copy to disc which I do not want to lose.
As an added note the recorders make several loud noises similar to whirring and starting, stopping for about 20 seconds or so after the tray opens and whether a disc is loaded or not. It says "reading" on the display and of course "no read" after the noise quits with or without a disc.
I dug an old Pany ES-15 out of the closet and hooked it up and it is very quiet. After a disc is loaded it reads quietly and very quickly and if the tray is shut with no disc inserted it says no disc on the display.
