AVS › AVS Forum › 3D Central › 3D Displays › Help me understand auto-switching
post #1 of 4
I have a Panny VT20 with a UVerse source. The panny will only show ESPN3d in 3d if I manually switch the 3d mode to side-by-side.
I then have to switch it back to auto once I want to go back to 2D programming.
I would expect this when going through my Onkyo 605 AVR, but I get the same results while going directly from the STB->TV (via HDMI of course).
So who's to fault? The Uverse STB or the television. I'd guess that the UVerse box is to blame, as I doubt they are passing some flag telling the TV that the content is 3d and in side-by-side.
I just want to understand how the auto-switching process should work.
post #2 of 4
Your STB is to blame. I have an HR23 DirecTV box, and when I go to ESPN3D, my VT20 goes straight into 3D mode. Pretty slick. All I do is turn the glasses on.
post #3 of 4
My PS3 sends it into 3D mode as well, as a postscript.
post #4 of 4
That's what I figured. Does it do this regardless of the programming being shown? I've only tested while the channel is off-air and that static slide is up saying ESPN 3D.
Do you know if the box has to send a flag giving this information?
  Back to Forum: 3D Displays
