I know this has been discussed, but it seems like many are still suffering this issue with Nvidia cards
Here's how I got got 4:4:4 Chroma Subsampling with Nvidia 4200M on my 32LD450.
I used this as a guide: http://hardforum.com/showpost.php?p=...0&postcount=22
1) Open a text editor and paste the following, but don't save it yet
REGEDIT4
[~paste key name from step 4~]
"OverrideEdidFlags0"=hex:1E,6D,01,00,00,00,FF,FF,04,00,00,00,7E,01,00
2) Open regedit
3) Navigate to HK_LOCAL_MACHINE\\SYSTEM\\ControlSet001\\Control\\Video\\{GU ID}\\0000\\
NOTE: {GUID} is your video card's unique id. To tell which one is the correct one, look for a \\{GUID}\\0000\\ that contains one or more keys that begin with "NV"
4) Once you found the correct {GUID}\\0000, right click on 0000, and select Copy Key Name
5) Go back to your text editor and paste the key name you just copied in between the square brackets
6) If you did it correctly, you should have a file that looks similar to this, but with your own unique GUID
REGEDIT4
[HKEY_LOCAL_MACHINE\\SYSTEM\\ControlSet001\\Control\\Video\\{ AAAAAAAA-BBBB-CCCC-DDDD-EEEEEEEEEEEE}\\0000]
7) Now save the file as "override.reg". NOTE: If you're using notepad, make sure you select "All Files" as your file type.
8) Double click on override.reg, and you'll be prompted with a warning. Click "yes".
9) Now, reboot your system, and you'll have RGB444 over HDMI cable to your 32LD450.
REGEDIT4
2) Open regedit
REGEDIT4
