Originally Posted by nuker43
well i pretty much give up. Every setting i try on the hdmi port yields crappy color. However when i put a vga cable from my computer to the tv it displays perfect 4:4:4 and 1080p. The only problem i now get with vga is that theres a little shadow the icons cast if theres a pure whit background. Seems i can't win with this tv and i am so close to returning it but that would mean using a broken westinghouse until a true 37 or 42 inch MONITOR comes out that isn't a tv.
That is definitely odd. Myself and Colmino have done extensive HDMI 1080p and 4:4:4 tests on the S-IPS LD450 and it passes just fine (result is here). Granted, neither of us have calibration devices to give us quantitative measurements, but we've been very happy with PC text quality and color reproduction. And this is based on comparing several other sets.
Are you still using a PC-labeled HDMI input? If so, get rid of the PC label and set the Edge Enhancer to Off. Then set your H and V Sharpness to around 35 and 55, respectively. That should give you a decent starting point, then fine tune the contrast/brightness/sharpness until your desired result.
I'm turning in my team green membership badge and decoder ring.
