AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK
The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK - Page 5
post #121 of 10211
Because doubling the power output only results in a 3db increase ....
1-2-4-8-16-32-64-128-256 (each doubling of power results in 3db increase)
so if going from 64W to 128W results in an increase of only 3db, then going from 105W to 125W would result in < 1db gain. This is also why if you want more power you don't upgrade from a 105W to a 125W AVR, rather you would want to add an external amp that is at least 250W or more, but even then, as noted above, you're still only looking at a 3db increase. In most cases adding an external AVR isn't going to do much more than what the AVR can do itself (unless using 4 ohm speakers, then it's pretty much required for louder volumes).
post #122 of 10211
Okay, I tried to find some screen shots of the Graphical User Interface (GUI) for the 3311CI, and I can't find any. Never having owned or used a Denon, I don't even know what any of it looks like.
I did find THIS post from the 3310CI thread that shows the volume overlay on the screen. Does anyone have any shots of the 3311 or another model that is confirmed to have the same (or very similar) GUI?
post #123 of 10211
Also doubling your speakers gains you 3db,also does not the speakers specs also come into play,sensitivity/spl roomsize,location etc...has anybody around here do such an upgrade and notice any difference? a 1909ci to a 2310 or 3310ci
post #124 of 10211
You people really down play amp power output, more power is always better even if its just 10 real watts. The big reason for small grains in power output per channel when you move up in the models is that there adding to 5, 7 or 9, 11 channels so the total is much higher. Your only fooling yourself if you think 125w won't sound any better than 90w per channel, unless you only use headphones or your speakers are pisspoor.
post #125 of 10211
I dont' think that more power will add anything important for the sound.
What is more important for me is the consistent that a receiver/amp can output to all speakers during the transmission of the sound to the speakers.
What is good to have 200W but fails miserly to deliver sound to all speakers at the same time??
Originally Posted by nickm11 View Post
One major problem with the 3311CI. It may have two HDMI outs, but only one choice for sound, either TV or Amps. So, if you have two TVs for the HDMIs and one is an HT, then you cant use the other on sound for a normal TV only setup.
What good is two HDMI outs if you can only do sound on one?
Saving money or bad design choice.
We bought the unit so we could run a variety of TVs though the Denon. One HDMI to the main Home Theater and the other going to a splitter and the other TVs. This would allow us to use a second input to the other TVs to watch DVD or whatever comes along.
The Yamaha 767 has dual hdmi independent outputs for a stealer price!!!
post #126 of 10211
What would you use "dual hdmi independent outputs" for. Yamaha is one of the worse for all channels driven, this unit if history means anything will only pump out 30 watts per channel X 7 20-20k
post #127 of 10211
This pic illustrates the difference between the Denon line GUIs. The 3311 GUI appears to be the same as the 3310.
http://www.synergysav.com/files/Denon-OSD.bmp
The GUI only overlays on some of my sources, but not BluRay. It's supposed to overlay on everything except a 3D source, which I don't have. I've tried playing with the video convert and i/p scaler settings per batpig's faq, with no luck. I'm going to try different HDMI ports to see if that changes anything.
Here's BatPig's faq, which provides an overview of the Tier1-3 OSD/GUIs.
http://www.batpigworld.com/fadq.html
post #128 of 10211
The GUI only overlays on some of my sources, but BluRay. It's supposed to overlay on everything except a 3D source, which I don't have. I've tried playing with the video convert and i/p scaler settings per batpig's faq, with no luck. I'm going to try different HDMI ports to see if that changes anything.
GUI is no big deal, once your HT is setup its not used much, as for needed level tweaks when watching a movie, I really don't need to see or have anyone else be annoyed when I tweak the sub, change the center or other on-the-fly changes.
post #129 of 10211
Originally Posted by batpig View Post
neither -- that has nothing to do with one or two HDMI outputs, the setting is exactly the same for one-HDMI-out models. The point of an AVR is not be a switcher to send audio to your TV's, it's to play SURROUND SOUND to your REAL speakers.
The point of dual monitor outputs is so that you can have a regular display and then a projector setup for "movie night". Or some other dual monitor setup. Not to distribute audio to different displays. Most people don't want to use their TV speakers anymore once they have a good speaker setup
They dont seem to want to explain the audio difference in there brochure material. Let's face it, they dont want to spend the money to work around the copy protection and the bit about the switcher is a bad argument, because I'm not asking for separate audio videos, I'm asking for dual audio and I'm pretty certain, that's a software issue. At the very least, it should be a combo output, not split to start with.
If it were not for copy protection, you would only need to have an on/off to the TV audio.
post #130 of 10211
. At the rate you're going .. you'll still be here on labor day wondering which model to get.
No I won`t. I got it actually for 28% off with shipping.
post #131 of 10211
Congrats on your new purchase! Perhaps you can give the thread some feedback as you setup the 3311. How did you get such a deep discount? Employee discount?
post #132 of 10211
not if you listen at volumes where you only use less than 5 watts/channel
if you are ACTUALLY using that type of power, driving speakers of medium efficiency to near-reference volumes, then you are correct. but you CANNOT make a blanket statement like that, you have fallen into the myth that better speakers need "better" power. What matters is their SPECS, you ROOM, and your LISTENING VOLUME.
most people have 88dB+ sensitive speakers in medium sized rooms, and are listening at 10-20dB below reference level even when cranking it up for movie night. Even lower for "typical" listening. That requires very little power..... and if your situation calls for a ton of power (e.g. big room, big volumes, inefficient speakers), the difference between 90 and 110 watts isn't going to be the "deal breaker".
post #133 of 10211
No I just bought a 58vt25 and a panasonic 350 3d blu-ray player(which I might also sell)once the ps3 can play 3d movies,now to sell my avr-1909.
post #134 of 10211
I like the option of more power for when I go deaf,or listening to music,should I rest the MP before selling???
post #135 of 10211
Thanx, but Yamaha just isnt Denon. No slight meant.
post #136 of 10211
How does the pioneer SC-35 compare to the 3311ci? Does pioneer let u use the scaler on hdmi outputs? I know previous models was pass thru only. How does qdeo Marvell processor compare to anchor bay 2015? Is ice power all that? How about MCACC vs Audyessy? I own a pioneer tv if that matters.
post #137 of 10211
Electronics Expo has a sale going on now using code SUMMER35 which will get you 24% off MSRP on the 3311!
post #138 of 10211
Holy Crap!, Just order one (unintentionally) trying to see whats the final shipping cost which happens to be free Nice deal..
Wow I haven't own a Denon AVR in some time.
Djoel
post #139 of 10211
Wow! That did it. I jumped on that deal too!!!
post #140 of 10211
One thing I have found with this unit is that it will display album artwork when an IPod is plugged into the USB port. A pleasant surprise!
Just got Audessey setup and will be watching a movie tonight. Looking forward to see what difference I can hear from my old Yamaha 663.
post #141 of 10211
Looking at the specs for the 3311 on the Denon website, I see a "-" instead of a checkmark next to "HDMI SACD support." Does that mean I wouldn't be able to play SACDs with my Oppo if it is connected via HDMI?
post #142 of 10211
It means the 3311 does not have a SACD decoder, so you would need the Oppo to decode the SACD and send as PCM over HDMI.
post #143 of 10211
It's interesting, I have my OPPO 83 set to output SACD and connected to the 3311 via HDMI only. SACD's play with no issues but when I check the audio input signal on the info menu of the 3311 it displays PCM 88khz.
I guess the OPPO knows somehow that the 3311 won't decode SACD.
DreamCatcher
post #144 of 10211
It will also display album artwork when using Pandora which I wasn't expecting.
This is my first receiver (working one) so I'm excited. I actually bought 2 3310's back to back and neither one of them worked. After the second one I decided to wait until the new 3311 came out. So far it's amazing and worth the wait.
I just had a question about configuring my subwoofer since this is my first home theater system. I am using a Klipsch SW-350 subwoofer that offers Low Pass Crossover and Low Pass control. Low pass crossover is for general purpose input and accepts LFE signal output of receiver. Low pass control allows you to select the upper frequency cutoff of subwoofer and frequencies above the control are filtered out allowing you to blend output with main speakers. Frequency is selectable from 40-150 HZ.
What is the best way to set this up? I'm not certain if my subwoofer has a direct mode or not and what all of this means. Does the Auyssey auto setup take care of everything or do I need to make changes on the subwoofer?
post #145 of 10211
A great place to start is BatPig's Denon/Audyssey FAQ: http://batpigworld.com/fadq.html#audyssey
I don't have my 3311 yet, and this will be my first Denon/Audyssey, but I think I have a pretty good grasp of things thanks to that FAQ and some other experience I have, so here is my attempt at answering your questions:
If you use the subwoofer output of the Denon, you should not need to use the crossover or low pass control in your sub. If you can turn that stuff off completely, that would be "direct mode" (your best option) and if you cannot turn it off, just set the crossover to the highest frequency it has which allows it the widest range of sound.
Then let Audyssey do it's magic. If Audyssey sets any crossovers to something higher than 80Hz, leave it, but if it sets any lower than 80Hz, raise it up to 80Hz and set your all your speakers to "small". Done. Enjoy your calibrated system.
If anything in the sound bugs you on any of your sources, consult the FAQ for common issues and their solutions.
post #146 of 10211
this is one of the actual benefits of HDMI -- it's a 2-way communication, with each device reporting its capabilities to each other, so the Oppo actually DOES "know" that the AVR will not accept DSD so it automatically decodes to PCM.
post #147 of 10211
Would someone report the following:
- Connect PS3 via HDMI, auto audio & video setup (e.g. 7.1 CH LPCM, 1080p), leave PS3 in the menu (idle)
- Connect your headphones to 3311
- Crank up the volume until you can just start to hear faint buzz/noise
- Report back the volume level
For reference, on my 2310 I start to hear the presence of the noise at -25dB.
If video conversion is on, the noise becomes 10dB louder, so it can be heard starting at -35dB volume (with headphones).
I'm considering trading up to 3310/3311/991 if it performs noticeably better.
post #148 of 10211
Just wondering what your reason is to changing or not changing the crossover frequency set by Audyssey. Unless you're changing it just to be in line with the THX spec, the crossover frequency is not arbitrary. It is dependent on your specific room and equipment. If audyssey sets a crossover to 60hz, it does so for a reason and may set up filters to smooth the response according to that crossover. If you change the crossover to a higher frequency, those filters may no longer be applied correctly. If you don't trust what Audyssey came up with and you want to change the crossover, I would suggest having some type of measurement system or plenty of listening tests to see if the change is for the better.
-Mike
post #149 of 10211
Mike - have you read through the Audyssey section of my FAQ linked above? Your understanding is off on a few things....
this is FALSE. Audyssey simply measures your speakers and reports the results back to the receiver, which actually DOES make an arbitrary decision on crossovers, setting them at the lowest point above the measured roll-off. Audyssey is NOT in control of the crossovers in the consumer implementation; thus, do not assume you are getting an "optimized" crossover set for smoothest response. Audyssey specifically recommends this procedure of raising crossovers that are set too low by the receiver, since the subwoofer channel filters are much higher resolution, and many receivers will set the crossovers very low (or worse, set the speakers to "large").
this is also FALSE. The filters are INDEPENDENT of the crossovers. Audyssey filters all speakers across their entire operating range, regardless of where the crossover point is set. Again, have you read that section of my FAQ? The only risk of losing out on the filters would be if you LOWER them significantly.
post #150 of 10211
I've been looking, off and on, at replacing my AVR-3300. Right now I only use it for audio, except for a VCR. My only HD source is an OTA STB. The main thing is I am using a (getting old but nice) Pioneer Elite Pro RP CRT TV which has DVI + HDCP inputs @ 1080i (and many analog but I am willing to go all digital).
Right now I am using HDMI - DVI cables from my HD STB and also an SD DVR. Will that setup work on the 3311ci such that I can connect both units to the AVR and run the HDMI - DVI cable from the AVR to my Pioneer TV? I've never had any HDCP problem with a couple different stbs, but maybe from the AVR it would be more of a hassle? No doubt someday I would get a BD but connecting one of those isn't a deal killer right now.
My end goal would be to connect the VCR (S video/stereo), a CD/DVD (component/optical (preferred) or coax), a DVDR (HDMI), a phono (MM) and an HD OTA STB (HDMI/optical coax) as inputs with HDMI-DVI as the only output (aside from a couple of stereo audio sources and tape monitor or out to DVDR)
So it seems the AVR 3311ci would meet this requirement, unless the HDMI-DVI is a problem?
scott s.
