yes, if you specifically select the "1080p/24" option for resolution output, it will scale ALL input signals to 1080p/24 output for that source.
leaving it on the AUTO setting should allow 1080p signals to pass through untouched, while scaling anything below 1080p up to 1080p/60.
However, with certain combinations of source/AVR/TV, the "auto" setting screws up and converts 1080p/24 to 1080p/60 on the way through. If this is happening to you, you should probably just disable the scaler and let your BDP handle the scaling. So try "auto" for resolution... if it is letting 1080p/24 pass through, then you are fine with that setting.
(on a side note, DVD's are 480i, not 480p)
you can tweak each input separately!
