Originally Posted by JChin
Hi dools767, the bass management is handled by the AVR so set the LowPass knob to "BYPASS", also set Phase to "0", set Sub Volume about half and then run Auto Setup.
Yes, anytime a setting is made on the Sub or even moving speakers or furnitures around Audyssey Setup should be rerun.
The Subwoofer Mode setting and LPF for LFE setting is found by clicking on "Speaker Config Check" and then "Bass Setting".
I have the PS3 Slim and have try both Bitstream and LPCM and I don't hear a difference (but others may disagree). I leave it on Bitstream because of the blue light
.Thanks I do notice an improvement in bass after setting the crossover to bypass as it had been about halfway. I notice that this time running the Audyssey setup the volume suggestion for my right sound was about a half of a decibel lower. Perhaps changing the subwoofer changed that?
One thing though I do have my PS3 slim set to bitstream but the light on my 3311 is green. Should it be blue? I am watching a Blu Ray with 6.1 DTS-HD master audio lossless and have it running in PLII Cinema mode.
What site did you use?
