Originally Posted by sdaltman82
I just purchased the 3311CI and received it on friday. I have been trying to set it up for 5.1 sound. I feel like i have tried everything and still cannot get my surround l/r speakers to have ANY sound (not even the channel level test). It's not my speakers since I plugged my surround l/r speakers into the front l/r and they worked. I can get them work in Front Wide but that's definitely not ideal since i really can't set it up using Audyssey. FYI, both the surround l/r and surround back ports don't work, and i think i'm 100% sure everything is plugged in the correct position because i keep swapping the positions and nothing works.
I have the amp setup as "NORMAL" and Speakers config is:
Front: Small
Center: Small
Subwoofer: Yes
Surround: Small
All else set to none for now.
Do you think i have a defective unit, or is there some setting i'm completely missing? Any help will be greatly appreciated. Thank you!
Front: Small
Center: Small
Subwoofer: Yes
Surround: Small
Put you tongue directly on the surr l/r outputs while cranking the volume and see if you get that tingling sensation effect like when placing your tongue on a 9v battery.
I would just do the network reset which resets everything and try to re-run audyessy. Maybe you can also try the pre-amp outputs to see if they're getting a signal. Sure you didn't mess with the amp assign or something? I would just reset the entire system, check for latest firmware, and work from there....
Take 2 shots of whiskey and call Denon CS in the am.
