AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK
The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK - Page 106
post #3151 of 10228
New owner of an AVR-991 here. Thanks to all, especially batpig and jdsmoothie. I purchased this unit for a number of reasons and the information here was priceless.
I recently bought four Polk Audio Monitor 70 Series IIs for the corners and I thought I made a mistake since my old Pioneer receiver would not utilize more than the front two speakers for music and barely used them for 5.1 while watching movies. This receiver changes all that. I also have a Polk Audio CS2 Series II center and the subwoofer from my old Pioneer HTIB. It sounds great, even though I have not yet run Audyssey since I'm going to change my furniture layout shortly.
I have a DLNA server with all of my music on it and it's been flawless. No network issues except for one time it did retry once on a firmware upgrade. Holding in the power button until it restarted got things going again and the upgrade completed.
Music performance is great and PLII Music simulated surround is mindblowing. You can really appreciate the music quality and range (or lack thereof) of some the tracks. I haven't really played a lot with Internet radio or the other services yet but I plan to. I've honestly been too busy reading the 105 pages of this thread. Now that I have it, I may have to read it again
I have a Panasonic TH-50PHD6UY display with the added DVI board and, while I was a little worried that I needed a 1080p display, it has absolutely no problems feeding it HDMI through an HDMI->DVI cable. I ran component to it with my old set up and used the DVi for an HTPC that didn't last very long. Great picture after all these years.
I also use a PS3 and have no issues with it either. It uses my DLNA server to stream movies and it works like a champ through the AVR-991.
I've used the web interface, the iPhone app, the Android app but may actually write a Blackberry app to control the receiver. This feature is such a bonus. Truthfully, I'm still amazed at the on-screen menus that I never had before. How did I do without them?
My current speaker set up is weird because of my family room. The two front/two back speakers are in a rhomboid pattern where my four speakers are evenly apart but my rear right speaker is roughly between my two front speakers and the rear left speaker is off to the left. Out of curiosity, could Audyssey make it work? I think I'll just move the furniture around but that Panny is heavy
Thanks again for all the discussion. I'm sure I'll be back for advise and I certainly will be watching this thread regularly as I learn more about what this receiver can do.
post #3152 of 10228
I'd probably go with moving the furniture, although I would still suggest running AUTO SETUP now just to see what it will do for you. Either that or simply angle the speakers and TV to turn the rhomboid into a rectangle.
post #3153 of 10228
This 3311 is my first amp with the hdmi capability and I might have had unrealistic expectations so I wanted to ask the group. I hate it when my projector changes modes. I was under the impression that with upscaling that I could keep a consistent signal going to the projector. I have setup upscaling for Apple TV and FiOS to 1080p but when changing from one 1080p source to another, the projector loses signal for a brief moment when the change occurs. This results in the projector resyncing for several seconds. Is there any way for the amp to keep a consistent output to the projector so it doesn't switch between sources of the same output resolution?
post #3154 of 10228
It's unclear whether you have the sources upscaling to 1080p or the 3311. If you have the sources set to NATIVE, set them to their highest resolution which should reduce any HDMI handshaking issues, although changing sources in general will result in a resyncing or HDMI handshaking to occur.
post #3155 of 10228
if your expectation is that there will be zero re-sync time when switching sources because they have the same resolution, then, yes, you have unrealistic expectations
ANY time there is a change in the HDMI "chain" there will be a re-sync. In the case of switching from ATV to FiOS, the source has changed so the whole chain of devices (source / AVR / display) needs to renegotiate and confirm HDCP compliance. It doesn't matter that they are the same resolution (as the projector sees it), one signal disappears, and then a new signal appears, so the PJ must renegotiate the "handshake" with the HDMI chain.
post #3156 of 10228
Just started looking at this thread, and wow, this seems to be a very special receiver. This 2011 model seems to be a lot more than I thought it would be...not just 3d capable. Am I just getting caught up in the hype (as can happen at first glance), or do you guys think likewise, that this model is a lot better than the 3310 because of all the new features / upgrades?
post #3157 of 10228
The most important upgrade is the more advanced version of Audyssey MultEQ XT over the basic MultEQ version in the 3310 and lower level models.
post #3158 of 10228
IMHO the 3311 is a big step forward from the 3310. When the 2809 was replaced by the 3310, they took away some "audiophile features" like MultEQ XT and slapped in networking, changed the first number to "3" to make it look fancier and jacked the msrp up from $1199 to $1499.
It made the 3310 a poor value at the time of release... and the "street price" from retailers soon dropped as a reflection of that. The 3311 however has hit a big "sweet spot" in terms of features for the price, with the return of MultEQ XT, iPod USB port, Audyssey DSX, and a $300 drop in msrp.
The lower level models (2311/891 and down) didn't really gain much for the xx11 model year, just 3D support really. But the 3311 and 4311 took a pretty big step forward from their xx10 counterparts.
post #3159 of 10228
Completely agree with batpig.......
and I'd take it a step further in saying that the 3311 has many advantages over even the 4310...
3D capabilities
ability to EQ up to 11.1 speakers
ability to select on the fly different speaker configurations, ie DPLIIx or DPLIIz, without re-running Audyssey
faster EQ'ing setup
more useful remote
more reliable networking
lower price.......
DreamCatcher
post #3160 of 10228
Anybody knows if the 3311ci will get the update for apple airplay.
post #3161 of 10228
This was just discussed yesterday. The answer is yes. It should be available on Nov 25 for $49.
post #3162 of 10228
I heard it might be free at first so I didn't want to pay $49, but I figure somebody might have already tried this. It's an order form for the airplay upgrade.
I'm new so I can't post urls but I found this link:
shop.denon.com/Webpage.aspx?WebpageId=4&CategoryId=18&uidStatus=0
post #3163 of 10228
Although originally it was to be a free upgrade for the first 3 weeks of it's release via a rebate, that apparently is no longer the case.
post #3164 of 10228
Hi all,
This is my first post in this forum.
I just received my brand new 3311ci and would like to cheat and use your knowledge instead of reading 106 pages of info.
My old system used the pre-outs for the mains, to DBX 2496 crossover and then to the sub and mains, this worked well for many years.
Unfortunatley the default setting (after auto setup) is to crossover my front large speakers at 40hz.
I need the full signal to mains to allow my sub to get down to 20hz (cut off with crossover)
FYI - Pandora was up and running in the first couple of mins that it took me to get there!
John
post #3165 of 10228
Let's not blow things out of proportion .... folks generally only come here when they have problems with or questions about the AVR. Of those that have posted about network issues, several were resolved by the "network reset" and a few others by NOT using a wireless connection, rather hardwired to the modem. To date, only about 3 posters have indicated they ended up sending in their AVR for repair which did indeed resolve their network connection issue.
Looks like I will probably be #4. Even direct connection does not fix networking issues and the AVR has been acting wierd. I went into configuration menu after a system reset to try to configure my inputs. After I exited the menu I could no longer access menu functionality again and then remote stopped working. I did another system reset and unit is working ok, other than networking.
post #3166 of 10228
Count me as #5 re: network / gui issues. No matter whether I reset or connect directly, the internal web page and updates do not function. If I reset and try to update, I get partially through and then I get an error: Update fail 10.
I brought the unit in today for repair and the tech there said that he has 3 other 3311s with a similar problem. He told me that when he attempts to update the firmware thought the serial port, it fails as well. Denon has not been able to come up with a fix yet according to him. If they can not fix the unit within 30 days, they will replace it.
post #3167 of 10228
Well, I think I didnt need to ask question.
The receiver is sending all frequencies to the crossover!
There is alot to learn with a new reciever.
Should I have any fear of new firmare updates?
John
post #3168 of 10228
As I mention before I lost my Internet connection on my 3311ci so last week I took it back to the Mom &Pop store where I bought it they called me today and told me Denon is giving me a new one and I will have it Friday. Happy to get a new one just hope I have no problems with it. Also I hope everyone else with this problem get theirs replaced also.
post #3169 of 10228
I peeled the black felt off my oddysy mic last week when I was reading the post last week and someone asked if you should peal off the grey sticker and said yes. Mine did not come with a grey sticker so I pealed off the felt. Two post later said do not peel of black felt. I put the oddisy mic in a zip lock bag so that it would not colect dust right away I did not keep the black felt and it is gone(I lost it). My question is will the mic work as it should or do I need a new mic. If you guys could ask I believe oddisy chris if I keep it in a zip lock bag would I be ok or do I need the black felt can I get sent to me or where can I get one. I live in Kingston, ON, Canada.
tks spager
post #3170 of 10228
Do you have Network Standby (p. 39) set to YES?
post #3171 of 10228
tks spager
Why not simply ask him yourself either in the Audyssey thread or via the Ask Audyssey on the Audyssey website?
post #3172 of 10228
Does anyone know if the air play update will also stream video?
post #3173 of 10228
It's been confirmed that it won't.
post #3174 of 10228
Sent my question to audysy teck. Will post and let the forum know thier reply for my bone head mistake.
tks jd
post #3175 of 10228
I was getting the Update fail 10 then one day I did the network reset and it found the new firmware and installed and completed it no problem.
post #3176 of 10228
Sometimes when I listen to music I leave the denon image that apears on my LCD tv. My question is is this ok for fear of burning the image on to the LCD screen?
tia spager
post #3177 of 10228
I've been looking to get a good receiver and the 3311 seems for the price to fit the bill..closest other one is the pioneer sc35 for the price. I saw that a bunch of guys bought from EE,can someone please link the page to the coupon for discount,i couldnt find it..hope most of the issues ive read about are resolved by now, are they?
if anyone has info on how the 3311 would match up with polk rti10 fronts for bi amping id appreciate it.
post #3178 of 10228
^ Hi, welcome. The 3311 with MultEQXT will make your Polks sing. If you are not running ext power amps and an active crossover there's really no need to bother with biamp.
Just call or chat directly with EE and mention the great deals you've heard on AVS so they'll give you their best price right off, per jdsmoothie's suggestion. You could also call J&R for a price as EE will price match.
post #3179 of 10228
You don't need a coupon, simply call them up and tell them you heard about them from AVS forum and want their best price ... it will be the same or in some cases even better than what any coupon would provide.
Beat me that time SOM!
post #3180 of 10228
I am also looking at this receiver for my Polks. Right now it has boiled down to the Onkyo TX-NR708 and the AVR991. What is "EE"?
