Originally Posted by D0T-C0M
ahhh ok yes I am using HDMI to my SAT box that would explain why it doesn't work. Is there a reason why it can't use the HDMI video? Is this a bug or a hardware/software limitation?
If I connect the component cable and HDMI together will the receiver use the HDMI when I select SAT/CBL input?
It's an HDMI HDCP limitation.
If you assign both cable inputs to the same source name the HDMI input will take priority so it's best to assign the component input to an unused source name (or just remove the HDMI cable and connect an optical cable).
