AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK
The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK - Page 167
post #4981 of 10207
I have a few noob questions after reading through the 3311 Owner’s Manual, Batpig’s Guide and the Audyssey Set Up Guide. I have not performed the Audyssey set up yet (manual set up only so far) and I am a bit confused on the Audyssey/Multi EQ XT stuff.
1. Once Audyssey has been set up, is there any going back to not using it? In other words, if I don’t like the resulting sound quality, do I just turn Multi EQ to “off” and the filtering/calibrations/corrections are cancelled? Does it then revert to my previous manual settings? I have a very weird room configuration where both of my main viewing/listening seats are to the sides slightly (about 15-20 degrees off the center channel to either side). This is the only configuration I can set up in the room and I’m not sure what kind of results I may get with the Audyssey setup. My physical set up looks like seating diagram in the Audyssey Set Up Guide, except no couch in the middle. There is a fireplace where the couch is shown.
2. If I make changes after Audyssey has been set up (e.g. crossover setting, speaker distance, channel level, large/small), do I have to run Audyssey again? It says that in the Owner’s manual. However, the Audyssey Set Up Guide seems to indicate you don’t have to rerun Audyssey, if for example, you change the crossover or change speakers size from large to small. Which instructions are correct?
3. If say I want to just listen to CD music in just stereo (2.1), but I don’t like how Audyssey is making it sound (but I like the blu-ray movie sound), can I just turn off Multi EQ (reference Question #1)? Would my previous manual settings come back then, or would I have to set them up again?
4. Do I still have to calibrate the Subwoofer volume with the 3311? The Audyssey Set Up Guide says you can skip those steps (Section G) with a newer receiver. I assume the 3311 is new enough to not have to do this?
5. I understand that if I want to pass through my audio and video from my cable box to the TV via the 3311, with no video processing, I have to leave Video Conversion to On and I/P Scaler to Off. But does this mean that I have to leave the 3311 on to get sound? In other words, can I just pass both the video and sound through the 3311 and get the sound through the TV speakers only? Then if I want to get sound through the receiver, I just turn it on? Probably not that simple, huh?
Sorry for these crazy questions, but I am coming from a 12 year old Marantz surround sound receiver without anything like Audyssey or video processing.
post #4982 of 10207
Originally Posted by Dark Rider View Post
Chicks dig professional audio gear Seriously though, if you don't want to use the crown amp and the sub is good enough and worth the time/effort, you could also integrate a decent plate amp on the back which would give you a crossover as well for a pretty modest investment:
http://www.parts-express.com/wizards...AT&srchCat=505
There's also the infamous Polk PSW-505, which can be had for a good price from Newegg. It's certainly not the last word in low end extension, but is powerful, well made, and sounds great for both HT and music applications. I actually ended up going with two of them and selling a single eD A2-300, because I liked the pair of 505's better for music.
Thanks Dark Rider... I'll check it out.
I forgot to add... don't they though. LOL
post #4983 of 10207
Originally Posted by TechnoG View Post
I have a few noob questions after reading through the 3311 Owner's Manual, Batpig's Guide and the Audyssey Set Up Guide. I have not performed the Audyssey set up yet (manual set up only so far) and I am a bit confused on the Audyssey/Multi EQ XT stuff.
1. Once Audyssey has been set up, is there any going back to not using it? In other words, if I don't like the resulting sound quality, do I just turn Multi EQ to off and the filtering/calibrations/corrections are cancelled? Does it then revert to my previous manual settings? I have a very weird room configuration where both of my main viewing/listening seats are to the sides slightly (about 15-20 degrees off the center channel to either side). This is the only configuration I can set up in the room and I'm not sure what kind of results I may get with the Audyssey setup. My physical set up looks like seating diagram in the Audyssey Set Up Guide, except no couch in the middle. There is a fireplace where the couch is shown.
2. If I make changes after Audyssey has been set up (e.g. crossover setting, speaker distance, channel level, large/small), do I have to run Audyssey again? It says that in the Owner's manual. However, the Audyssey Set Up Guide seems to indicate you don't have to rerun Audyssey, if for example, you change the crossover or change speakers size from large to small. Which instructions are correct?
3. If say I want to just listen to CD music in just stereo (2.1), but I don't like how Audyssey is making it sound (but I like the blu-ray movie sound), can I just turn off Multi EQ (reference Question #1)? Would my previous manual settings come back then, or would I have to set them up again?
I'll try to help. I just got the reciever last Thursday but I'm pretty versed in most of this stuff:
1- Yes you can just turn Audyssey MULTIEQ XT off.
2- No need to run Audyssey again. Just make changes to speaker size, crossovers, etc and it will still apply MULTIEQ XT. Not sure why it states it in the manual. I was confused at first too.
3- I beleive if you have set up an manual EQ then you can toggle to that or just turn Audyssey off.
4- Audyssey does calibrate subwoofer volume for you. However some say, if you're a tweaker to adjust the subs volume beofre you run Audyssey so that Audyssey sets it to + or - 3db. Not sure if this is done for any reason other OCD reasons but, mine luckily came up exactly at -3db after running Audyssey.
5- Going off my deteriorating memory somewhere in the settings for HDMI inputs you can set "Power On" to specific HDMI inputs. This will allow video and audio to be sent to the TV while the receiver is off.
I'm sure others can chime in as well.
post #4984 of 10207
To add to what has already been provided ...
I believe you're just reading this wrong in the manual as it refers to re-running AUTO SETUP only if speaker configuration (adding more speakers) or physical placement has changed. Otherwise, you're good to make the other changes noted.
Yes, you do. Only the higher levels can skip these steps (ie. 4310, 4311, etc.).
5. In other words, can I just pass both the video and sound through the 3311 and get the sound through the TV speakers only? Then if I want to get sound through the receiver, I just turn it on? Probably not that simple, huh?
Yes, you can pass HDMI audio/video with the AVR in Standby by setting HDMI Control to ON and then either setting the specific HDMI jack # you have the HDMI source connected to or set to LAST to pass the last source selected prior to going into Standby.
post #4985 of 10207
Space2001,
I am having the same issue with my Denon 3311CI and have the Harmony remote. Could you share how you fixed the issue? Thanks!
Originally Posted by space2001 View Post
Thanks jdsmoothie. I figured out how to get it working and even do a passthrough to my tv.
is there any discrete ir codes that allows me to sellect monitor 1.
and monitor 2.
post #4986 of 10207
Sorry to bug you guys about this, but I still haven't got any answer to my question.
Is there a way to get the upnp music lists (when using net/usb) displayed on the monitor or is the only way to browse it via the screen on the amp?
post #4987 of 10207
I was just curious. Has anyone on here bought their receiver from electronics expo or 6ave? I know they have pretty good prices every once in a while but I was told by a local dealer that there is no way they could be selling for that cheap. He said that more then likely they are not "new" units even though they are stated as new. Just wanted to know if anyone had any experience with these stores and if the receivers you got from them were ok or if you had some problems. Is there a way to tell if the receiver I receive is 'B' stock? Thanks!
post #4988 of 10207
I doubt any store can get away with selling
used electronics as new. There are very hefty
laws against doing that.
6th ave electronics is very reputable. Bought
my Denon 3311 from them for much less than
what other people have been buying from.
post #4989 of 10207
Any way to tell that your product is actually new though and not "B" stock? Didn't know if there was some sticker on it or if you could call Denon and give them the serial number and they could check it.
post #4990 of 10207
I've bought from both... my 1910 from 6ave and my 3311 from EE. Both were courteous, authorized dealers, who shipped fast and had excellent pricing. Both were also new sealed products and definitely not B stock!
My media lists show up on mine with no problems. In fact, the 3311 also picks up my PlayOn (used with my PS3) upnp media server as well, and shows it to me through my hdmi display. I do like the fact that you don't need to turn the display on though, since I use a projector.
post #4991 of 10207
Originally Posted by NittanyLouie View Post
Thanks for your ongoing posts jdsmoothie. As a new 991 owner I find your experience and insights to be invaluable! After ending up in an endless firmware update loop on my first try I successfully made it through the ether img update. I've now been presented with the airplay upgrade option. Have you used this and if so what's your take so far? Currently I have 300 gb of music on my iMac in AIFF sync'd to 2 ipod classics which I play through a Wadia 170i Transport (bypassing the DAC in the ipod and using the DAC in my new 991). The music sounds great as it did on my old pioneer elite. only downside is that you have to use the ipod dial wheel to select your music. On on screen display would be so much easier.
Airplay only works with i-pod touch 3rd generation or better I believe, i-pads and i-phones and does not do video, although it will play your music and play list via i-tunes on your mac or pc. If you want a little better gui and video buy an apple tv 2. I bought an i-pod touch for this very reason and it works great.
post #4992 of 10207
Once in a while? They generally start out at 25% off MSRP right from the release date, although keep in mind that wholesale on these puppies is likely no more than 50% of MSRP. Best Buy is Denon's largest customer and has been selling their HDMI 1.3 units from 2009 at up to 75% off, to include the $1999 MSRP 4310 for $550. These resellers sell thousands of these AVRs and therefore can cut that profit margin down to much smaller proportions whereas your local dealer mom and pop shop cannot and therefore has to sell at MSRP. These resellers are also authorized Denon resellers which means they are required to get their stock directly from Denon so you can be rest assured that you are getting new "A" stock units unless of course they are specificaly advertised as "open box."
post #4993 of 10207
Yeabut... What happens if you change a crossover? Wouldn't that require a change to the EQ? I mean, so you can change the crossover, but are you then going to get a wacky/inappropriate EQ curve? Or are EQ and crossover applied separately?
post #4994 of 10207
Ah, thanks for clearing that out! I thought it was strange that everything showed up through web, osd and android app but not via hdmi. I guess i'll have to dig deeper into this! Perhaps the receiver doesn't play well with my tv (it took hours before i got it to display the signal from my connected computer.) But it's strange since all other menus seems to show on the television screen, i'm only having trouble with "net/usb". Flickr photos shows up after they have been downloaded though.
And i agree that its nice that you are able to use only the receiver to browse the media sources!
One final question, can the receiver play videos? And if so which formats are supported?
post #4995 of 10207
Has anyone bought from Abes of Maine? I got my 3311 from them and it broke after two months. Now, I wonder if it was because they sell "B" stock.
The box was sealed and the contents seemed new, but now I wonder...
post #4996 of 10207
I'm not getting overlays (volume, menu) on certain channels from my cable box. I think I'm only getting them on channels that are 1920x1080.
I set both conversion and scaling on, even changed from "AUTO" format to 1080p. No dice. I have a particular "problem channel" that broadcasts at 1280x720. It still comes through on the TV as 1280x720. If I turn I/P scaling off, the UI comes up at 720x480?! If I turn I/P scaling on, the UI comes up at 1920x1080, but not as an overlay. In both cases, it changes the resolution when I bring up the menu.
This is crazy: scaling does NOT scale. All it does it change the resolution that the menu comes up at and not as an overlay at that.
The only way I've been able to get the overlay on all channels is to have the cable box convert to 1080i. But the cable box's scaling is terrible - horrible artifacts with any motion - so I don't want to do that just to get the overlays.
Edit: Damned thing just started working, and I didn't change a thing! The only thing I can think is that scaling doesn't take effect until you change channels. That is, I think it doesn't apply the scaling until it sees a new channel, so you can fiddle with the settings till the cows come home, and it isn't going to make any difference until you switch to a different signal. I switched to a standard-def channel to see what it did there. When I switched it back to "problem channel", the overlay worked and the signal to the TV is 1080p.
Most frustrating piece of equipment I have ever owned. Dunno who it was designed for, but certainly not people from this planet.
Edit 2: Ack! It stopped working again! I made some unrelated changes in the menu: I added the remote code for my TV. When I was done with that: no overlay and no scaling. Changed channels, then back again, overlay came back.
Edit 3: Still works inconsistently. Seems to depend on HOW you change channels on the cable box! If I change from one channel to another with channel up/down on the cable box, then I DON'T get the overlay, EVEN if the format is 1080! If I select the channel using numeric keys, then I DO get the overlay. If I use the channel guide, then I DON'T get the overlay. Makes no sense.
post #4997 of 10207
As you know I did from 6ave Mac, got it in exactly 6 days. Brand spanking new with that new AVR scent. My Marantz SR5003 a few years back, was purchased there and same thing. I think a local dealer will say that merely because he cannot compete with a place that sells to 50 states IMHO.
post #4998 of 10207
I believe EQ and X-over are seperate entities. In other words you are not telling the receiver to you want to mess with EQ by changing the X-over you are merely telling it where you want the lower Frequencies "cut off" in regards to the LFE channel. If any of the EQ would fall into that range then it is merely passed to the subwoofer, it doesn't totally rework the Audyssey EQ.
At least that is my simplistic view on it. I've messed with Audyssey, MCACC, etc for years and never had any issues with changing the crossover point. Of course I'm sure that someone can explain it better than I can.
post #4999 of 10207
But here's the rub: (from BatPig's site)
So, feel free to go to MANUAL SETUP > SPEAKER SETUP and change things like speaker crossovers, channel levels, etc. This will not affect Audyssey's filters. For example, you may want to bump up the center channel by 1-2 dB to make the dialogue easier to hear, or you may want to bump down the subwoofer a bit because the bass is too loud.
That being said, as a rule of thumb you should NOT lower any crossovers below where Auto Setup set them! This is because Audyssey's MultEQ filters only extend down to the measured bass response (-3dB point) of each speaker. For example, let's say you are using a small satellite speaker system and Audyssey measures that your left front speaker has "real" bass response down to only 113Hz; it will stop filtering the speaker below that point. Whether you set the crossover at 60Hz, 80Hz, or 150Hz the Audyssey EQ filter will still be independent of that, it will always go down to 113Hz and then taper off. But if you set the crossover to 60Hz, you have "exposed" a large hole in the frequency response that is not filtered by MultEQ, and that your speaker has been measured to not produce in your room! It is better to leave these low frequencies to the subwoofer channel, which actually has much higher resolution filters (because most acoustical problems are in the low frequencies).
post #5000 of 10207
Yeah I knew this and thought you did too by reading the Audyssey FAQ. Sorry guess I should have said that. You shouldn't lower the crossover settings that Audyssey sets. It is ok however to RAISE the crossovers.
post #5001 of 10207
I have not used Airplay, however, your best bet is to follow the Airplay thread here. Based on what I've read though, although the upgrade will benefit a few folks, the better option appears to be adding an Apple TV $99) which would also allow for video streaming as the Airplay upgrade only allows audio streaming.
post #5002 of 10207
Just because an item is defective doesn't mean it's "B" stock. You can read in these threads about numerous defective AVRs out of the box. It happens. Although Abe's of Maine used to be an authorized e-tailer, I notice they're no longer listed on Denon's website.
post #5003 of 10207
Back in the day Abe's of Maine's claim to
fame was the fact that they were dirt cheap
but were opening boxes, taking out accessories,
and then selling them to the customers separately.
That is one etailer that I will never purchase from.
Perhaps they are still up to the same practice which
is why Denon is not associated with them.
Definitely do not purchase from anyone that is not
an authorized retailer -- especially with some of the
problems that owners are having with the 3311.
post #5004 of 10207
Thanks, Ron. I wish I had asked here before I made the purchase. I have definitively learned my lesson with them on a separate attempt to buy the AVR-991. I had to cancel that order after they started playing games with the stock availability.
post #5005 of 10207
Thanks for the input guys. I just am being extra cautious. I figured my dealer was just trying to talk me into buying from him but it still made me a little nervous. He said he knows the place that does the repairs and once they are finished they look brand new. I just didn't know if there was an actual way to check your receiver to tell if it was B stock. I'd love to buy from my local dealer but the online prices are just too cheap and money talks haha. I wonder if Best Buy matches online prices (6ave).
post #5006 of 10207
Generally the only time that BB/Magnolia will match on-line etailer prices is if the on-line etailer also has a store front and it is located in the same state as the BB/Magnolia (eg. NJ) you want to negotiate with. If you believe you will be doing more business with your local dealer, you might consider trying to get him to come down to an acceptable level that you can live with as you'll generally get better service with the local dealer. If he's not willing to budge on price .... feel confident in buying from either Electronics Expo or 6Ave as both are authorized and reputable dealers.
post #5007 of 10207
Ya I agree and would love to give my local dealer more business but with tax included, it is like $300 more from him even with his discount. I told him about the online prices and he said they are losing money and that he couldn't go any lower then his discounted quote to me. Oh well..
post #5008 of 10207
Stan,
I am not saying you will get open box equipment.
I would check everything carefully to make sure all
accessories are included and everything looks freshly
packed.
The downside is that you didn't buy it from an authorized
dealer. That being the case, you may have difficulties if
you experience any of the networking problems that seem
to be running rampant here.
post #5009 of 10207
Stan,
packed.
may have? That's what I was trying to say initially. The 3311 network issue started on mine after only 2 months of ownership!
post #5010 of 10207
Update on this: it appears to be a bug. I'd like others to test this.
I've tracked it down a bit more. I'm using a Scientific Atlanta 8240HDC (Cox cable) as a source. If I turn on the receiver and am already tuned to a 1280x960 channel, the receiver will NOT scale.
But if I tune-away to a 1920x1024 channel, then TUNE BACK to the SAME 1280x960 channel, THEN the receiver will scale to 1080p, and I will get the overlays. Same channel. Just depends on how I navigated there.
It has nothing to do with whether you direct-tune with the keypad, use the guide, channel up/down, etc. Has to do with the format of the signal immediately proceeding.
I'm guessing has something to do with detection of signal change?
The cable box is set to not scale. Have confirmed with "INFO" that the input signal is 1280x960, the output signal is 1920x1024 when it works, 1280x960 when it doesn't...
I THINK the problem may be limited to the case where you turn the receiver on with the cable box already on and tuned to a channel that is not 1080.
