Energy speakers rock!!! Lynn also awesome.
Definitely get a Harmony or something like it. Build quality is a bit lower than expected - plastic faceplate, knobs and display screen. Anyway, you can't tell from a distance, and how often do we even go up to receiver to adjust it.
though that'll raise the level of difficulty as you'll need to disable and change some stuff to have it co-exist with your other router.
At least I can rule out the AVR.
