Originally Posted by blowe46
Initially, it would just flicker to green and then off to a screen with just static after a few minutes.
Then, I did a microprocessor reset which resulted in the port not working at all. The DENON log just appears right now when I switch to the DVR input.
Is there anything else I could provide. I am happy to test any suggestions.
Are your other ports working Ok? Make sure that the right hdmi input is selected for that source after the micro reset you did. You could try a different hdmi cable. How long of cable do you use from avr to tv and source to avr and do you use a hdmi wall jack for wire management?
