Originally Posted by nordvest
This might seem like a strange question but I`ll ask it anyway
Is there any setting I can use so that I get sound just from the center speaker while watcing tv? I`m asking because for caual tv viewing the whole surround experience can be a bit overwheliming for all kinds of programs all the time...
Ideally I wouls have liked to program a setup where I downmix everything to the center channel and assigned a Quick Select for it and another Quick select for normal surround when I`m watching for films, sports etc. Is this possible??
(Obviously I could have used just the tv speakers in this scenario but they are unbearable to listen to and besides I need the auto lip sync on the Denon to correct the audio delay from my PVR)
You have a few options available to you ...
(1) Use "Multi CH Stereo" surround mode which replicates the FL/FR speaker audio to the SL/SR speakers placing the dialogue closer to your ears,
(2) Use a set of wireless headphones or or perhaps try TV EARS.
(3) Add an analog cable connection from the cable/sat box to the AVR to pass audio to Zone 2. Use either an additional single Zone 2 speaker or use an A/B switch and connect the existing center speaker to both the center speaker posts as well as the SBL speaker posts. When you want to listen to the center speaker only, set Amp Assign to Zone 2/3 Mono (p. 53), turn the main zone to OFF, turn Zone 2 ON, flip the speaker switch to "B" and you should be getting audio from the center speaker only.
