AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Optoma TX1080 DLP help please
post #1 of 4
I have been using this for about 6 months. It has a sony blue ray that goes through an Onkyo THX9100. All of a sudden all I get on screen is Source not found. If I switch to the AUX and run the play station, it finds it, flashes and says the same, "source not found". I can't get it to see the feed from the HDMI cable. I hooked the blue ray player directly into it with a different HDMI cable and it says the same thing. It has to be the projector. The bulb works fine, it just says "source not found.
Any ideas on where to go next? I can't find anything on it and really hope something didn't get zapped somehow. Any help would be appreciated.
post #2 of 4
Did you try another source? Perhaps another cable? Usually that message indicates the HDCP on the HDMI cable didn't lock...
post #3 of 4
If there's a source lock feature in the Optoma's menu try that and hit the HDMI button on the remote as the source is on, try pulling the cable and reconnecting it also.
post #4 of 4
Did you get a response? I just got one yesterday and I am getting the same thing. No problem with VGA. Pulled the projector down and connected directly to a blu-ray player with a short cable to rule out cable and/or receiver and got the same thing.
