I figured I'd start here first since this issue may be stemmed from multiple areas of my Home Theater setup. My issues is my graphics card (and sound to go with it) need to re-installed via device manager every few days. It seems random and I haven't pin pointed what sets it off. I have noticed when I am using my PS3 and switch my universal remote to view my HTPC the screen is blank when viewing the PC. What I have to do then is Ctrl+Alt+delete to log out then either reboot or go to my device manager and reinstall my graphics card. But it isn't always when I use my PS3, sometimes it is when I leave PC on over night like when I am downloading a large file. This isn't that huge of a deal since I have gotten used to the fastest way to do it but I lose all my graphic cards setting in my ATI Catalyst program.
My setup is as followed
* Home theater PC Specs: Gigabyte P55-U3DR w/ i5-750, Asus ATI Radeon 4650, (The rest is all new but don't think it would apply)
* All my Home Theater components are routed through my Pioneer HD, AV receiver.
* Windows 7 Ultimate 64Bit
* HDMI Cables for HTPC, PS3 and Component for DVD (like that matters)
I hope with these details someone can help or at least guide me in the correct direction.
Thanks for reading and thank you in advance for any input.
