AVS › AVS Forum › Audio › Speakers › Speakers Wall Mount Help
post #1 of 2
I purchase these Cerwin-Vega VE Series VE-5M - Left / right channel speakers - 2-way - black ash for my surround and rear 7.1 setup. http://www.amazon.com/Cerwin-Vega-VE.../dp/B000LSG09Q. I have these allready Speaker Wall Mounting Bracket - Black (Max 10LBS) - Set of 2 http://www.monoprice.com/products/pr...seq=1&format=2
will these mounts hold them on wall,will replace my old speakers in photo,like to have same setup. i hate to put many wholes in my fresh walls with new mounts.
post #2 of 2
The specs state 8 lbs, but they don't say if that is for the pair, or each speaker. Either way, the 10 lbs max for the mounts should work for you.
  Back to Forum: Speakers
