Hello,
We are in the process of building our custom home. We are not finishing the basement right away, but I have designed it have a HT in the future. My desire is to have something similar to Swithey's build (http://www.avsforum.com/avs-vb/showthread.php?t=620108) as our rooms are similar sizes (his being 14.5 x 17.5 and mine being 15'8" W x 18" L with 8'1" ceilings.
I have attached a copy of the basement layout. The walls with the vertical lines are load bearing walls so I can not change the current layout.
Just to give you an idea of what I am planning on doing, I was thinking of having speakers behind an AT screen of ~125" and 2 rows of seats with a riser. The screen would be on the north side of the theatre (if the top of the drawing is north) and having the equipment/server in the maintenance storage are near the mechanical room.
My big question is the HVAC. I am able to tell the HVAC guys what I want to do with regards to runs for the house so I am trying to get everyone's opinion. I live in Alberta and it gets as cold as -40 C and as hot as +40C. Sound isolation and sound proofing are my big concerns. I do not want sound to travel to the upstairs levels via ductwork. From what I have read, mostly from Dennis, is to tell the HVAC guys what temperature you would like it and what you want the sound of the air flow to be at certain points from the vents. I have a lot of time to plan the little details, but the big, unfixable things need to be addressed now. Please weigh in with any and all advice. Thank you.
Basement.pdf 393.9384765625k . file
