Originally Posted by
wwwgnojhamcom
other questions that you can tackle if you like:
what is the USB port for on the back of the cable box?
It depends on the cable company as well as which cable box and specific model you have. Most techies use the port to attach an external hard drive to expand the storage capacity of their DVR. But ... my advice... forget about the USB on your cable box... save that for "after" you get your system up and running. Right now you have bigger fish to fry.
wwwgnojhamcom
likewise for the internet port on the cable box, can i run a cable from it to the 867 and get internet (or does that output typically require a modem)?
That would be great if it would work, but don't count on it. Due to IP address issues etc, you will probably find you will need to run a CAT5 from your cable company modem to a router and then from the router run separate feeds out to your computer equipment and V867. In my case, (in addition to my V867), my Blu-Ray and Roku box also have internet ports. I ended up running a single CAT5 from my router over to the area of my entertainment center. At my entertainment center I plugged the CAT5 into a
NETGEAR GS105NA 5 Port Switch so I could split out feeds to the V867, Blu-Ray and Roku.
wwwgnojhamcom
can i run a rf cable from the cable box to the 867 to use as the fm antenna? (i think i remember way back when that the cable line carried radio feed)
... based on all the other member responses to this question you should pretty much assume it won't work in your case wither. I can tell you I tried it myself and had no luck. (Time Warner Cable)
wwwgnojhamcom
no sweat
i would have assumed that optical was better quality somehow, but after reading up on it, i will probably use coax when possible
I assumed the same thing as well. Hooked my system up via optical. Then again I didn't have much choice. While my TV has HDMI and optical ports... it lacks a RCA coax fittings for audio out. While I've read a few negative comments about using optical cables I personally haven't experienced any problems.
Krutsch
@wwwgnojhamcom ... it sounds like you have a great deal to learn and the 867 is fairly complicated for a CE device. And you haven't even gotten to the networking part.
When you get to configuring the network its actually pretty simple from the V867 side of the equation (basically point and click inside the 867 setup menu. My problem was getting my computers set up to talk to the 867. I found
these instructions were a big help.
joe01880
The CNet review of the 667 said "this may be more reciever than you need" and the 867 sounds a little more complicated then does the 667 and the 667 can be complicated. So for some those may be wise, money and agrevation saving words.
I owned the 667 for one month and can attest to the aggravation comment. I about pulled my hair out with all the cabling and all the permutations and combinations with the various settings. Anyway, I returned it and got a 867 when the price of the 867 dropped to what I paid for the 667. Fact: For the most part, the 867 isn't any more complicated. After owning both units, I think the statement about the 667 being more receiver than you need is due to all the settings and control functions that most people won't ever use. I am not a AV techie by any means and I can honestly say I had my 667 hooked up and running with all my peripherals in about 45 minutes (all HDMI). It was only when I got into fine tuning and playing with all the settings it that I began to question why I didn't just buy a home theater in a box.
Honestly... the 667 and 867 are then same from a complexity standpoint. In the area of firmware updates the 867 is actually easier. The only thing the 867 adds in terms of "added complexity" would be setting up the network and DNLA. The good news is setting up the network is not a necessity when it comes to the initial stages of cabling up all the equipment and getting your HT system up and running. Its just icing on the cake.
As to aggravating... I've been fighting with my system for 3 days trying to get everything to play with my Harmony remote. (i.e., the correct equipment power up sequence, determining the proper number of milliseconds for the command delays, the fact that the VX67 series "remembers" and always powers up with last input setting (e.g. HDMI2 etc.)
