Sup yall. This is my first home theater setup and was wanting a bit of advice on my 5.1 setup. I just want to make sure I get things right the first time around. Because of the room I'm putting it in I have to snake my rear speaker wires and my sub cable under the carpet. My rear speakers will run 15 feet under plus about 5 feet for slack and to run up the shelf or stand(haven't decided). My sub will run about 20 feet under carpet. My front towers will just be about 4 feet away from the receiver. And my center will just be about 3 feet above my receiver.
A couple questions I had were:
What gauge of speaker wire should I run to my fronts/center?
What gauge of wire should I run for under the carpet for my rears?
What is a good place to get some flat speaker wire?
As well any other advice/feedback would be greatly appreciated.
Thanks ahead of time yall.
My set up is:
(All speakers from av123)
Fronts: x-statik Open Baffle Loudspeakers
Center: x-voce Open Baffle Center Loudspeaker
Rears: ELT525M Mini Monitors
Sub: MFW-15 Subwoofer
A/V Receiver: Onkyo TX-NR708 (as soon as it goes on sale in July)
Possible Amplifier: Emotiva XPA-5
My set up is:
