Originally Posted by mhdiab
Can we get some setup specifics?
There is no way the receiver will do 9 speakers as it has 7 amps
So for 9.1 there are pre-outs and it should be possible. It may NOT be possible with height but 9.1 should still be possible
So using a 2 channel amplifier through the 9.1 pre-outs would be step 1
1) hook up your Rear surrounds through the amp and your front height through the ports for them on the receiver -- do you get 9.1?
2) if above didn't work hook up the speakers to the receiver in a "regular" 7.1 fasion and hook 2 separate speakers through the 2-channel amplifier. I understand that this will most likely not get you the height format, but this is about verifying if the receiver will do 9.1
There should be a sound format for option 2 that gives you 9.1. It may not be the height option, but one of the other formats should produce 9.1 in that setup
Actually "martinefski" tried step 1, connected rear surrounds to 2-ch amp but no difference.
-- I disagree with you.
