Originally Posted by
tesseract67
You should re-read the beginning of this thread, Terry J.
Yep. Started fine enough. Op asked for advice, obliquely mentioned 'dunno about cables'. First answer straight forward, don't worry about them. Perfectly fine and reasonable answer given the context of the thread.
Then YOU started it off, pushing your cable agenda. And your cable agenda pushing buddies jumped in (including Mr 'I tell lies and cheat and deceive as well as sell expensive cables').
And you have the gall to put cables on the same footing as room treatment? You too seem to becoming a liar.
Is it not true that you yourself state cables are very subtle? (don't make me chase your posts, be a man and admit it and save me the bother). If so, why are you bringing it to the table in a 'help me start my stereo system' thread as WELL as equate it with room treatments?
S*hit Tess, I don't give a flying f*ck what you have in your system, but for christ's sake don't be a hypocrite and change your story when it suits you (subtle one minute when it suits your point, equal to room treatments when it suits another point).
tesseract67
So far, the conclusion we are coming to is the same old AVS 2 channel BS.
All amplifiers, CD players, and cables are the same because controlled testing bears this out. Who really believes this?
Where was this statement made in the thread? Well done tess, two strikes in one go. I thought we made some little progress in the other thread, now we start again with the same old crap dredged up again.
In any case, if the guy already has his pre and power amps, WHY do we need to advise him on those selections??? So the absence of mention of amps in this thread is NOT saying 'they sound the same'!
Can we have a bit of discriminatory thinking please?
Please, keep this thread FOR THE OP and help him. Don't turn it into your own personal crusade.
