I think this deserves a separate thread from other LG threads.
According to LG technical support via phone and email, the LH90 with Real Cinema On and TruMotion Off gives 48fps when viewing 24p input such as Blu-ray disc. Real Cinema and TruMotion Off gives 24fps--yes, that is what I was told by LG technical support. I think that is worth repeating, With Real Cinema and TruMotion Off you get 24fps.
I guess the reviewer at CNET was confused when he said:
"We did appreciate the LG's Real Cinema setting, however, which functioned as advertised to preserve the true frame rate of film as long as the 240Hz function was disabled. We set our Blu-ray player to 1080p/24 output mode, turned the Real Cinema setting on, and fed the LG our favorite test clip for evaluating film cadence, the helicopter flyover of the Intrepid from "I Am Legend." The LH90 showed the proper amount of judder without the slight hitching motion characteristic of 2:3 pull-down, which returned when we set Real Cinema to Off."
http://reviews.cnet.com/flat-panel-t...ml?tag=rvwBody
