"The design and usability of the UI are fantastic."
The UI is from 2004. There is no such thing as a UI from 2004 that is "fantastic". "Serviceable and barely competent" is the best you can hope for from a 2004 UI. You may as well be trying to tell us that bookmaking and printing from 1910 are "fantastic", given the point in the computer's history that we are in. To put it in further perspective, you could have just told tried to tell us that Windows 3.1 has a "fantastic" UI in 1996 when everyone else is using Windows 95, to the same effect.
"By far the biggest problem is the network infrastructure"
I would argue that far greater issues are a lack of clear design focus in the UI, a lack of the right hand knowing what the left hand is doing, and half-implemented features as a strikingly common occurrence. Ever been notified by PSN that a system update is required? Does it just start it for you? No, of course not. It tells you to go somewhere else to do that.
The PS3's interface absolutely reeks of being designed in a vacuum, as if the PS2 and PSP were the only other options available to consumers. They seem to be absolutely blind to everything that is going on around them in the industry.
Everyone else: Do I rant about the PS3? Absolutely. Software that doesn't work worth a damn when there are obvious examples in the wild of far better execution on varying concepts is worthy of every drop of bile that I spit at it. The PS3 makes a pretty good networked media player, and an acceptable Bluray player. Everything it does on the gaming side though? It's fine if it's your only option, but when you own everything else of note that will run a modern game, the PS3 is extremely sad in it's execution and consumer friendliness in comparison.
