Originally Posted by brakel
I had like a dozen GTA saves and I deleted all but three. Do I need to delete the ones off the cloud or the ones on my local ps3 or in both places? I'm thinking that if I only delete from the cloud then it will just try to save them again tonight. That's why I was wondering if there was a manager of some sort where I could indicate to save only the three most recent gta saves.
That would be a good feature, but it didn't have that option when I was a Plus member. If you tell it to store your saves for that particular game to the cloud, it will create a backup of any new saves.
I do believe it will overwrite the same/updated save...but if you create multiple saves on your HDD, it will create multiple saves online...until it fills up.
