Originally Posted by
michael goldman
I throw myself on the mercy of the Board
Yes, I have used the search function to try to get the consensus of the best settings for the 52 909.
However this is difficult to do do even with the search function when threads get to be this large.
Any info is appreciated in advance
Michael
Ps just received the TV yesterday and 3D blows me away
From Doug Blackburn
The HX909 Owner's thread is cluttered with discussions of many "side issues" but little discussion about experiences with and recommendations for specific settings.
This thread will discuss the merits and drawbacks of various settings as well as keep the recommended settings up to date in 1 place.
This list of recommended settings is subject to change as more is learned about the HX909. I've used a video signal generator to determine correct settings where possible. I won't be able to say a whole lot about instrumented measurements until my review is published in WSR, but I see no harm in discussing basic settings.
(NEW - Try sending RGB to the HX909 instead of YCbCr - if you notice that images are sharper, continue to use RGB - note that sending RGB means keeping 16-235 (different manufacturers have different names for this mode... limited, standard, light are some of them) for 16-235 sources like Blu-ray and switching to 0-255 mode for PC sources and perhaps for some games.)
Updated November 3, 2010 (only change is paragraph "New" above)
Dark Room Viewing setting recommendations:
Scene Select Mode: General
2D Settings
Custom
Backlight - 2
Picture - 82 (produces +/- 35 fL combined with Backlight 2)
Brightness - 50 (remarkable... a factory default that's correct!)
Color - 50
Hue - 0
Color Temp - Warm2 (which is a little too red, Warm1 has a larger Blue bias than the red/yellow bias in Warm2 - you may prefer Warm1 if you are not having the TV calibrated, but you need 1 week of "acclimation" to Warm2 and Warm1 before making a choice - and no switching back and forth... watch each mode exclusively for 1 week before deciding which mode to stick with)
Sharpness - lost my notes and the TV is gone... easily checked with a sharpness test pattern available in just about all test/setup discs - and check it for every Scene Select mode and every Picture Mode you use, because the proper setting does change considerably when you change modes.
Noise Reduction - Low seems harmless for good quality images, helps worse qulity images a little - med and high do hurt detail in images.
MPEG Noise - (ditto)
Motionflow - Clear1 (still preferred overall, but Smooth is "interesting" though very "video looking" compared to all other settings - lots of motion artifacts in Smooth mode if there's a lot of motion on the screen)
CineMotion - Auto1 (this removes 3:2 pulldown from standard definition sources like DVD and uses frame interpolation to improve motion). Auto2 mode removes 3:2 pulldown but does not add interpolated frames. This setting does NOTHING for 720 or 1080 sources.
Black Corrector - Off
Adv. Contrast Enhancer - Off
Gamma - -2 (-2 setting averages 2.3, but it is higher at 30%, lower at 90% - good for 2D). If midtones seem too dark, use -1 to brighten midtones a bit. Black and white do not change when you adjust this control, but everything in between black and white will get lighter (higher numbers) or darker (lower numbers).
LED Dynamic Control - Standard (it would be a mistake to pay extra for this TV and not use this setting - it may not be P-E-R-F-E-C-T but it's better than leaving it off or Low) This is the Local Dimming control.
Auto Light Limiter - Off
Clear White - Off
Live Color - Off
Detail Enhancer - Off
Edge Enhancer - Off
Warmup time for 3D is about 45 minutes for new panels, decreases to 15 minutes as viewing time accumulates. Shutter glasses take 5 minutes or so when new but decreases to around 1 minute after they have been used for a while. Colder rooms may increase warmup times.
3D Settings
General - Custom
Backlight - Max - (no adjustment available in 3D mode) but varies greatly depending on what Scene Select Mode is being used.
Picture - try 87 to avoid color drift in highlights, but it may look too dark... use whatever setting makes the picture acceptably bright, knowing that the more you raise the setting above 87, the more color shift there will be. You may be forced to use Max and just have to live with the color shifts.
Brightness - 50
Color - 50
Hue - 0
Color Temp - Neutral (surprise! This was arrived at using an expensive meter with the shutter glasses over the lens of the meter and turned on... the glasses change color rather dramatically between being off and on so they MUST be on for measurements taken through them)
Sharpness - varies with different combinations of Scene Select and Mode, I recommend always using your own test/setup disc with Sharpness evaluation pattern to determine the best Sharpness setting since this TV seems a little unpredictable. Sometimes every setting from Min-55 looks the same (no sharpening applied, other times, the Min setting is required to get no sharpening.
Noise Reduction - (off, 3D Blu-ray doesn't need it)
Motionflow - Not Available in 3D mode
CineMotion - Not Available in 3D mode
Gamma - use 0 unless picture looks too dark. If you need more brightness in the midtones, try +1 or +2.
LED Dynamic Control - N/A
Auto Light Limiter - N/A
Clear White - Off
Live Color - Off
Edge Enhancer - Off
Always use a test/setup disc to determine the best settings for Brightness and Sharpness on your TV - the discs don't help all that much with Color/Tint settings though, due to the blue filters needed for those modes being perfectly accurate. TVs with a Blue-only mode can have the Color and Tint controls set quite accurately (usually).
