AVS › AVS Forum › Video Components › Home Theater Computers › Cannot get two extender xboxes to use WMC at the same time
post #1 of 2
I have been trying to get help at the green button.com, but I am getting no response over there. I tried posting a link to my thread but since I have less than three posts I cannot do it
I explain my dilemma in the thread, but a summary would be that I cannot get my two xboxes to extend my wmc pc at the same time. There is no issue getting both on the network or on xbox live on the same time, just using windows media center.
If I setup one xbox with the other xbox off, the xbox that I setup last is the only one that works.
If I setup one xbox with the other xbox on, then both xboxes work so long as both xboxes are on.
I reset my switch and router, nothing changed. I checked the ip address of each xbox, and they are both different.
I cannot find any solution online. I friend highly suggested coming to the this site, said you guys are the best. What do I do?
post #2 of 2
I will try it tomorrow when I get a chance but I am 99% sure I have done it before. I have two 360s running off one pc and I have never seen an issue like this.
I may be wrong but I think it is at least possible. ya I just tried and it worked fine for me
