I too suffered stuttering and video stalling when trying to play full bitrate BluRay rips in MKV container. To be clear, these are MakeMKV rips, with no compression so the video files are about 25 gigs each, and their full bitrate was preserved.
Here is my setup:
DNS-321 NAS (with SMB share) --> WRT310N v2 (w/ DD-WRT firmware) --> WDTV Live
The stuttering was so unpredictable. It would stutter at some points in a movie but when I would replay that particular part of the movie later, there would be no problem whatsoever. Difficult problem to isolate when it keeps moving around.
I tried running a crossover cable directly from DNS-321 to WDTV Live. This worked without stuttering as far as I could test!
Since I was using a crossover I assigned IP addresses manually to both the WDTV Live and the DNS-321.
After I assigned the static IPs, I reinserted the router into the network path. I also then forced the DNS-321 to use 100 MBit (disabling gigabit). I did this because the WDTV Live is only 100 Mbit anyways, and I thought it would help, maybe I'm wrong.
After making these changes I haven't noticed any stuttering after playing the parts of movies where stuttering was present.
So in summary : Assign static manual IPs to the NAS and the WDTV Live, and force the NAS to use 100 Mbit instead of gigabit.
Perhaps the DNS-321 has a flakey gigabit connection, or perhaps the router doesn't like translating between a gigabit connected device and a 100 Mbit connected device. Either way it seems to be working now.
What do you guys think? Has anyone else tried something like this?
Here is my setup:
