I'm pretty sure it's partly software related. I have seen other TV's do this and even tested the movies I use as a sort of primer on a Vizio 120Hz LCD. The same problem occurs but with nowhere near the flicker and artifacting as my Samsung. It has something to do with the way the interpolated frames are calculated. The Vizio did a much better than my Samsung at similar settings. Can they fix it with a firmware update, I don't know since this has apparently been a 3-year ongoing issue. I have yet to hear back from them. The best thing you can do is call and make it a point that you are dissatisfied with the issues and that you have read on many forums that you aren't the only one.Originally Posted by Ticmxman
My 3 week old ES7100 has the judder issue if I use AMP on any setting other than clear or off and while I may decide I do not like the smoothing effect I would like for it to work properly as an option. Is this purely a software issue that Samsung can fix with a update or is it hardware related and will they provide a fix? Also do other brands of LEDs have similar problems? I looked at the LG LM7600 and 8600 this weekend and they have some appeal.
