Originally Posted by tomwil
When the value "HL-DT-ST" was also deleted from that key, the Start button now shows.
However, the results I am getting from Nero CD-DVD Speed seems to be suspect, as my tested discs show no errors and a Quality score of 100. Perhaps the LG drive cannot report errors to Nero properly, which is why LG was blocked from Nero?
If you have any other suggestions, they would be most welcomed!
Using Nero and LG, I have never scanned a disc that came back error free. Most of my discs scan with a score in the mid 90's, like in the picture I posted earlier.
This next picture I enclosed is of a disc I rejected. Although the disc plays fine on my DVD player, I did see a colour impurity on the disc after burning on my stand-alone. I scanned it and sure enough Nero (with my LG PC burner) shown plenty of errors around the 3-gig space. Just like my visual inspection shown bad colour in a spot. So obviously my LG burner reads errors just fine using Nero DVD speed.
I did read a few rumors that LG made Nero exclude the quality test because the slow read time (less then real time) puts extra stress on the burner. My only suggestion is that you go into the advanced menu - uncheck the jitter test and put the test length all the way to the right - accuracy instead of speed - like in the image I included. And try again.
.) The Verbatims I buy are model number 94852, DataLifePlus 8x DVD-R Shiny Silver Top. At the moment, no one is gouging for TY yet, so I ordered 600 of those as well while they're still available.
