AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Mediatek or Reon chip?
post #1 of 3
It's been a while since I've studied up on the upconverting chips in all these different format players, so I thought maybe someone here could answer my question.
Which chip is (hopefully objectively) better for SD upconverting? The Mediatek found in my old OPPO 971 or the Reon-VX chip in my Toshiba HD-XA2? The only reason I'm keeping either of these players around is for SD playback.
I'm trying to thin the heard out and I want to keep which ever one has better SD upconverting.
Thanks all,
Rob
post #2 of 3
Thanks all,
Rob
You can see some test reports here:
OPPO 971: http://www.hometheaterhifi.com/cgi-b...PDV971H%20(DVI)
Toshiba HD-XA2: http://www.hometheaterhifi.com/cgi-b...HD-XA2%20(HDMI)
Both get very high scores. If there are no observable differences in image quality then I would pick based on other criteria.
The OPPO uses Faroudja for deinterlacing and scaling. I forget if the decoder is Mediatek but that is what OPPO has used in their later players.
-Bill
post #3 of 3
I'd expect most people to prefer the de-interlacing and scaling of the XA2 over the Faroudja in the older Oppo. YMMV.
There are other considerations too, like the snail's-pace boot and load times on the Toshiba. The Oppo is a universal player offering much more than DVD playback.
  Back to Forum: DVD Players (Standard Def)
