Hi everyone,
I recently got the samsung pn50c8000, and I have it connected to my PC via a DVI->HDMI cable.
Here's my issue: I have downloaded a bunch of 3D video sample files, but I can't get any of them to play right.
If I copy them to a USB stick and try to view them on the TV, I get "Unsupported Video Resolution".
If I use VLC player to play them, that works (I have to manually set the TV to left/right 3D mode), however the resolution makes them basically unwatchable (there are huge bars above and below the video file - I assume it is trying to scale the 3840x1080 resolution).
If I use the Stereoscopic Player, and set it to left/right mode, it fills up the whole screen perfectly, however it converts the file to the red/blue 3D instead!
So - how do I play these files correctly? Do I need to convert them somehow?
Thanks in advance.
Thanks in advance.
