Hi there mate,
Can't tell you that I have any experience with the Emotiva Subs but if they are anything like the other gear they manufacture they should be excellent in terms of value and performance. They have a special on right now. At $350 odd for a 12 inch model with free shipping, seems like a good deal. Details at:
http://emotiva.com/ultra_sub12.shtm
Just in case they are what you are after...
Best of luck,
Greg
Best of luck,
Greg
When you go away from grays and blacks you will get whatever color of the surfaces of the room reflected back onto the screen. So, the screen will have some purplish hue to it on brighter scenes. I'm not sure how significant the effect is as I'm not an expert. There are obviously high end theaters with colored walls, but that is probably a compromise for looks. The projector can be calibrated to get most of the wall hue out, so I wouldn't go nuts thinking about it if you really want purple.
The fabricmate is the way to go for frames if you want to save a lot of time.
