AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The 'I can't believe you want the largest room in the house' HT build.1
The 'I can't believe you want the largest room in the house' HT build.1 - Page 21
post #601 of 967
Easy ... just post PHOTOS !!!!
post #602 of 967
Oh, and David, as you have been the least guilty of self indulgently hijacking my thread, you are most welcome here anytime. Peter The Greek, it's gonna take a crap load of Coopers to get back into my good graces. And as for you Peter M, once you have my subs singing with your whiz bang computer thingamajigy, I think it's best you don't call me.... Atleast until your room is ready for movie nights!
post #603 of 967
LOL
The hardest part for me is going to be what will my kids do when I visit. Kids might be easy with movies but wifey will probably get bored.
Either way I will hope to see all fellow ozzie's HT when I get the chance later.
post #604 of 967
LOL
Send her shopping. Massive Westfield at Hornsby... 10 minutes away. Pick her up when she runs out of money (minimum 2 days worth). Sometimes I wonder why I'm single!!!
post #605 of 967
Originally Posted by Dingaling2004 View Post
I hope that we can shortly return to a time when I am again the master of my domain!
Mwahaha, this thread belongs to the Peters' now
....now about that beer
post #606 of 967
Oh, and David, as you have been the least guilty of self indulgently hijacking my thread, you are most welcome here anytime. Peter The Greek, it's gonna take a crap load of Coopers to get back into my good graces. And as for you Peter M, once you have my subs singing with your whiz bang computer thingamajigy, I think it's best you don't call me.... At least until your room is ready for movie nights!
So let me get this straight ... Peter The Greek is forgiven for simply turning up with beer ... I have to solve all your technical problems ??!!
Cheers,
post #607 of 967
Our bank account hardly will get us their let alone go shopping....lol
PLUS I am building all my speakers because I dont have the money for Danley and Procella stuff. All though the DTS10 kit was a great bargain.
post #608 of 967
Hi David. I'm hearing you on the budgetary front. Never ending bills on this project. Another 320 dollars today for the supertel insulation and 45.00 more for wood. Don't ask about the wood! My staffordshire bull terrier found one of the 3.4 metre lengths that I had cut for the screen frame and decided he wanted it for a stick more than I did for a frame. Oh well, it's been eventful! The Danleys were indeed a great bargain. The quality is superb and their service was first rate. A really nice company to deal with. So much so, I just had to buy two!
Ps. Pictures coming. More progress today.
post #609 of 967
I know, it's been a while since I have managed to post some photos of progress and the resultant hijacking of my thread because of it has spurred me into action.
The last update pretty much was building the Danleys, so I guess I should pick up there. I finished wiring them up, both internally and externally. Joined all of the wires with proper wire connectors and then attached to the wire to the cabinets with clips so that they don't move around. Copious amounts of insulation tape was used and I even wrapped the connectors in foam so that they would not knock against the cabinet. Was the best solution that I could think of.
It was simple at the end, but it was tricky getting my brain around wiring these speakers out of phase. Easy enough to do but the more I read, the more confused I became. Was originally going to wire them in phase and let the amp turn them out of phase but as I was running two DTS-10 subs, one for each channel of the Behringer EP-4000, I wired them out of phase as per the instructions. Used lots of the adhesive foam gasket when sealing up the ports and they were done. The subs were then painted black so they would not reflect light through my AT screen.
As the speaker had already been lugged into the theatre room from their assembly point (thanks Peter) the next job was to get them onto the stage. After a bit of re-organising, I decided to turn the Danleys onto their ends with the mouths pointing forwards. I won't have a lot of options for placement due to the large dimensions of the subs and my room width, but I managed to get the two subs plus the 3 x Niles LCR speakers onto the stage. I guess I can face the sub mouths towards the wall when I get into the testing phase. That would be about the only option I have. The LCR speakers need to be mounted on stands of the correct height... the Ikea tables are a $9.95 ea temp fix.
Yesterday, I went out to AGI insulation in Sydney and picked up some Supertel insulation. Filled a trailerload. The sheets are 1.2 metres x 2.4 metres (4 ft x 8 ft). $332.00 later...
I had never used this product, and whilst it's as dear as poison, it is fantastic stuff to work with. Only a little bit itchy and with an extendable blade, the 50mm (2 inch) material is dead easy to cut. The result being... about 1 hour, some cutting and four tubes of liquid nails later, I had a treated screen wall and surrounds...
I then reconnected the sub wiring and the stage is complete (I have some of the ceiling behind the screen wall left to do but will use some leftover material for this once the remaining treatments have been installed.
If I can get some more insulation done this weekend I will. Otherwise it will need to wait for during the week to get finished up. Then I can start the testing and tuning of the subs. 2 of the 3 required XLR cables have arrived so I am looking forward to that part. Even without the subs running, I did notice an improvement in the sound of the LCR speakers since treating the screen wall. The sound is a little more articulate. Should make an even bigger difference once those subs are firing. I really should make an effort to reinstall the theatre door before I expose my neighbours to that!
The work (and pile of receipts) continue...
Greg
post #610 of 967
Cheers,
Peter, don't look at it as solving all my technical problems. I am giving you the golden opportunity for some quality experiential learning on the DCX-2496 at absolutely no charge to you. I would have thought you would have appreciated my gesture!
post #611 of 967
What are those little things on the L/C/R of your subs?
post #612 of 967
Those photos look familiar to me for some reason???
10 to 1 they will perform better with those ports at the ground. I notice not but a few inches of space behind the subs. Almost like you designed it that way!
post #613 of 967
I know, those mains look pathetic against the subs. They are actually a reasonable size for this type of speaker. I wonder if they will keep up with the subs? In a word.... No. The look like satellites
post #614 of 967
Hi Tony, I was leaving you alone after LSU were so unceremoniously flogged! Thought you may need some 'alone time'.
Thanks for the hint on the subs. I will try up/down/front/back when I get them fired up. That is a two man job!
Design.... This build thread should have been called the 'wing and a prayer theater build' or the 'seat of my pants construction'. If you had your way there would have been another 6 inches back there but I didn't have the space. Shame. Worked out ok, me thinks.
post #615 of 967
Hi Greg,
Looking good !!!
Do you think you'll need to black out the fibreglass ? If so I'd suggest hanging fabric in front of it.
I agree with Tony that the sub mouths should be at the bottom. I'd definitely leave them facing forward, and keep the non-symmetric placement, so it's just a simple 180 deg spin required !!
Looking forward to playing with the DCX. I've now ordered mine so it will indeed be a valuable learning experience ... so that's another one I owe you !!
Cheers,
post #616 of 967
Agree on subs and blackness - can you paint fibreglass? perhaps just spray some of that leftover matt black paint on it?
Otherwise.......black trilogy?
The inside of the subs will also show through, depending on where they end up relative to the screen
post #617 of 967
Hi Greg,
Looking good !!!
Cheers,
I will rotate the subs around 180 degrees Peter. Impatience got the better of me and I went to Jaycar today. Don't know why I bothered with eBay. Purchased an XLR cable for 12 bucks. Set the amp to parallel mode and turned it on. Yeah Baby! It was sloppy and definitely needed tuning but it was enough to pummel my temp screen. And that was only one sub. For some reason the Left sub isn't going. The eq and amp are showing an output so it's somewhere in the connections. Feel free to come over any time mate. I can honestly say that I have NO idea where to start with the 2496. I'm sure it's a powerful piece of kit but I really have no idea. My previous subs have had two potentiometer knobs.... One for xover and one for volume. That's the limit of my experience. Would welcome any help as I know I haven't even scratched the surface with these subs. Even turned right down, they made a significant improvement to the sound of my room. Looking forward to releasing that potential.
I will get the subs sorted and then build the screen. Have decided to go for the Fidelio velvet for the entire screen wall. Not that there's much velvet left after a 145 inch screen is up there. It's going to cost about the same to do either the frame or the whole wall. I'll need about 4-5 metres so may as well do the lot and have no issues with leakage outside the screen. The LCR speakers will be behind the screen. The subs should be fine behind the velvet I think.
Looking forward to getting these subs dialled in properly!
post #618 of 967
I'm not sure how the fibreglass would take spray paint ... but it'd be worth trying on a bit of waste.
I wouldn't bother with Trilogy ... there's got to be something much cheaper when the look doesn't matter. Any speaker grill cloth would be OK.
Cheers,
post #619 of 967
I've downloaded the Behringer DCX control software, so once mine arrives and I've had a chance to play with it, I'll be over to have a go at yours. I believe it's just a standard RS232 cable between the PC and DCX so I'll try that first. PC control looks a lot easier than trying to use the DCX front panel with the tiny display.
Cheers,
post #620 of 967
Both subs are working.... Was just one of the plugs had come out during manouvering. Sound? Oh yeah! I had a very brief play with the 2496 and put a few basic settings in as best I could manage from the DTS10 thread and they are amazing. I really don't know how hard they go. My behringer ep4000 is at about 25 percent, the sub is set to -1 on the UMC1 gains and the whole room shakes. I could feel my Jean legs vibrating. Scuba Steve's demo disk has been copping a pounding! HTTYD is a movie I have watched over and over again but with the subs going it's like seeing it for the first time. I sure have been missing out. I think getting these subs going, even only on a basic level, has been the most rewarding part of this build to date. I had been anticipating getting them up and running for a couple of years.... Sure was worth the wait. Something tells me when these subs are kicking... It wouldn't matter how much Green Glue I used. I don't like the neighbors closest to me anyway!
post #621 of 967
LOL! How quickly you changed your tune on the neighbors. Good subs are like crack. You can't stop no matter the consequences.
Glad to see you having some FUN! It's been a long journey.
Got time for Messenger this morning? errrr evening.
post #622 of 967
Listen to you, Ghetto Tony! Maybe they weren't safari printed shorts you wore but the latest urban combat wear! Watch out.... Tone's in the hood!
post #623 of 967
I didn't want to bust on him (Tony told me "snitches get stitches") but Tony was one of the regulars at my old apartment complex purchasing his "goods."
He's got street cred, for sure.
post #624 of 967
The fun stuff continues! I have all of my timber cut up in lengths for the screen frame. This time I hid the timber from the prying jaws of my dog. It will be a very simple design, basically 2 lengths of 1x2 maple (nice and straight with square edges) which are 3.4 metres long (11.15 feet) and 4 lengths of 1.34 metre (4.4 feet) for vertical supports. This makes up a 145 inch 2.4:1 screen. The frame will be glued and screwed and I also have some L-brackets and T-brackets to hold it all together nice and square. Once that is done, I will probably cut down the white material sheet that I have in my room and make a temp screen stretched over the frame. I don't want to use the Seymour AV material until the room is carpeted and all the woodworking complete. With my luck, I will mark or puncture the screen and be up for more expensive freight for screen materials.
The screen will be surrounded by some 3 inch x 1 inch maple, which I will screw into the minimalist screen wall. This will be painted black and will act as the furring strip for my fabric track. At this stage, I am planning to butt the fabric track right up close to the screen frame and then have velvet covering the remainder of the screen wall. There isn't much left around the screen. I think 4-6 yards of material should cover it. Not cheap at 31 dollars per yard plus freight but I will see what else I can find over here that's cheaper. If not, I may just install some leftover track on the other side of the 3x1 furring channel and run black Trilogy one for the remainder of the screen wall and a 3 inch border of velvet surrounding the screen.
I am hoping to replace the door jamb tomorrow or Friday to accommodate the extra thickness of the clips, channel and double 5/8 drywall. If I can, I will scrape out the remainder of my 3-4 Green Glue buckets to laminate the door with two more layers of MDF or ply. This should give the door plenty of mass and stop the sound gushing out of my now-doorless room. This will leave me with one full bucket of Green Glue. Anyone need any?
A friend of mine in the carpet game is hopefully coming over on Monday to measure up and then hopefully carpet will be down within a fortnight or so. That will be a major milestone and pretty much, apart from the columns, mark the end of construction. Columns will come later. When I work out the easiest way to do it. Was going to be fiddly using the fabricmate track.
For the first time, I actually enjoyed my room and watched an entire movie, and at a volume which provided much satisfaction I purchased 'the Incredibles' on BD just a couple of days ago. I can't believe this movie hasn't appeared on either of the Home Theater Demo Discs. There are some serious dynamics on this one, with loud explosions, gunfire, rocket launches, aggressive surround usage and really great animation. Not the latest offering from the animated studios but I REALLY enjoyed it. Great system demo disc!
Will post some more pictures as the work continues.
Greg
post #625 of 967
I'll take your green glue. Not sure what the shipping would be.
Incredibles is a fun movie. Despicable me is also pretty good. Especially for the bass. I love all the kids movies but if you really want to have some fun get How to train your Dragon.
That Movie rocks. But I AM just a kid. LOL
Sounds like progress is coming along. Nice!!
Look forward to your pics. I think I am going to try and do a screen door like Japandave or whatever his name is. That was awesome.
post #626 of 967
Hey there David,
I have despicable me, in both 2D and 3D. The 3D is a blast... particularly the rollercoaster scene! Same for HTTYD. It's one of my favourite movies (and Tom's) and I have it also in 2D and 3D. The 3D version has the added benefit of 7.1, which is amazing. I wish my projector was 3D so that I could enjoy it in the theater room. 5.1 is still pretty good (5.2 actually with the twin subs )
I have tickets to see the HTTYD arena spectacular in March. Should be great to see the animatronic dragons on stage. I hope that it lives up to the hype. Looks like it's going to be pretty good....
http://www.youtube.com/watch?v=hJUDrjA6ZY8
At $80 bucks a ticket (no concessions) you would hope that it's a good show!
If you are interested in the GG let me know via PM mate.
post #627 of 967
Melbourne Brisbane Sydney.........Adelaide..NO. I will have to wait and hear what you think of it.
post #628 of 967
Wow Greg! I've been busy with work/family/life, so haven't been on the forum for a few weeks. I come back and you've managed to wrangle what look like 2 massive puppetshows into your room. I'm sure the sound of those puppies shakes the foundations, and as you say, no matter how much green glue, that noise ain't being contained. Can't wait to have my hair lift on it's head when the viewings are open
Personally things have progressed slow for me with xmas and the weather getting in the way, so I won't bore you with my minor details, other then cabling is almost done, gyprock is almost ordered and GE is closer then ever.
I might PM you about the GG, as I might have a need for a little more in the end, depending on how much you have, and how much it's going for.
Cheers mate
post #629 of 967
Well there you go. A local who needs some GG for his walls. Sounds like a much better candidate for it then me. As long as he post some pics.
post #630 of 967
Cory, watch your back for unmarked vans.
I think you're going to find that MOST movies make great demos when you've got the twins pounding away! I did.
Can you give us a little more detail on how you're currently using the DCX? Are you using the 5 filters recommended from Danley? If so, that's as far as I've gotten too.
