AVS › AVS Forum › Audio › Speakers › Help Needed on my first home theater, serious speaker advice needed...
post #1 of 6
thanks for answering my questions.
post #2 of 6
For music you can do much better but if you are happy with it thats all that matters.
post #3 of 6
baleted
post #4 of 6
I think an Onkyo 808 would be WAY overkill for something like that. I think I'd look at $500 receivers and put that extra $500 toward better speakers. You'll notice the extra money in the speakers WAY more than you will in the receiver.
post #5 of 6
The one thing I do NOT like the is the Polk PSW505 subwoofer. I would go with a Bic or HSU subwoofer.
And for side surrounds I might just use Monitor 50's the Monitor 60's might be overkill
post #6 of 6
Originally Posted by jaball77 View Post
i think an onkyo 808 would be way overkill for something like that. I think i'd look at $500 receivers and put that extra $500 toward better speakers. You'll notice the extra money in the speakers way more than you will in the receiver.
+1
  Back to Forum: Speakers
