Originally Posted by NightSkyMurals
I'm not quite sure that I understand the question. Are you asking if the painted mural, with the glow paint and fluorescing additive would work on a flat black ceiling? I will answer that question... and if you are talking about something totally different then please re-ask and I will answer again. Sorry, my brain went to sleep an hour ago.
The paint that I use is very hard to see on a ceiling that is anywhere between white and any color that is starting to get pretty dark. Some charcoal grays are about the end of the invisible scale. So, flat black will most likely show some of the stars when the lights are turned on.
Usually, it is only the larger stars (stars used to make the constellations) that are visible as well as a few of the larger background stars (I use about 15 different sized smaller stars for the background to give it the 3D look. Some of the larger of those stars might also be visible in the light too... but usually not very many.
When the black lights are turned on... the stars will be a blue color (you might need to play with the black light placements to get them just right to get the most stars to fluoresce). When the black lights are turned off, the stars will glow an Aqua color, with some glowing blue.
I hope this is what you were asking. again, if not, then please ask again or else feel free to email your questions to me.
Jeff
Jeff
I am getting ready to paint the stars on my ceiling... as you can see in the picture below my ceiling is pretty dark. The color is not quite black... it is a behr disney color called Galaxy Black... its like really really really dark blue... I will post pictures when I am done with the stars with lights on and off so you can get an idea of how the paint looks with lights on.
